+ Reply to Thread
Results 1 to 2 of 2
Thread: What will be the bandwidth required for a Building Management System(Bacnet Protocol)
    May 2015
    What will be the bandwidth required for a Building Management System(Bacnet Protocol) in the network?
    Jan 2017
    Montreal
    * Ethernet, the fastest at 10 Mbps with 100 Mbps also recently available.
    * ARCNET at 2.5 Mbps. Both
    * BACnet defines the MS/TP (master-slave/token-passing) network designed to run at speeds of 1 Mbps or less over twisted pair wiring
    *PTP for use over phone lines or hardwired EIA-232 connections.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
