    Jan 2015
    East Tenn
    On I Higher Note My Matched XR17 & 100% Varble Speed Furnace - Saved Me Big
    Here are some Numbers I have need checking Watts Used Daily , Gas Units Used Weekly during Heating Season .
    Watts Used during the A/C Only Summer Months ..
    New Home for Us First Yr.
    OK a few Comparisons : Year 1 : 2 Hot water Tanks 40 Gallon Tanks - 1 was Finally Turned Off and the Other
    Turns Down as the Electric Bill was Crazy in Winter _ Bother were set @ 130 degree . at First .
    Later 1 Off / Other Down to 118 Degrees . this bought only average Watts saving . .
    Added Better Lighting outside a lot more Eff% and Quiet = good saving of Watts .
    Added Better more Eff% Ref. & Washer / Drier = good saving on Watts
    OK the Above Saved 10000 Watts on average a day . 10Kwatts around 300 KW a Month .
    Took Out Gas Fireplace Added Wood Burning Insert - saved 155 Cu Meters & Got Much Better Heat .
    Second Yr. in New Home _ Added Insulation 10-11 inch on Top of Old R19 , so Now have R48
    Installed a New Hybrid Hot Water Tank 50 Gallons : Replaced 2 - 40 Gallon Electrics .. Big Watts another 10000 Watts Saved Daily .
    Installed Match _ Train A/C XR17 Straight _ No Reverse Refrig. which is Simple and Lower Cost .
    Installed Match High 94% 100 % Variable Gas _ Took Out 100% Electric and Heat Strips = Huge Saving on Watts
    Heat is Far Superior . 15000 - 20000 Watts Per Day . Gas went up average of 55 Cu Ft a Month .
    Saving Per Month on the Summer Bills $20.00 - $25.00 a Month / Winter Months = $90 to $150.00 Less Min.
    It Pays to Up Grade _ Tax - Right Offs also !
    Nov 2010
    Kansas
    That's Awesome!
    The statement below is my signature and just my overall feeling towards our industry and does not necessarily pertain to you nor this thread.
    There really isn't a legitimate excuse for not doing the job correctly!
    Jan 2015
    East Tenn
    Quote Originally Posted by Tech23 View Post
    That's Awesome!
    I'll try to Post a Pic of the Bill for Last Month During the Heat Wave .
    Those Numbers are very Conservative , as the We were only running the A/C on Older Unit
    about 6-8 Hours a day Max and the New System runs 12-16 Hours ..
    Electric Bill in Winter _ could $325.00 and My Highest Last Yr. during the Record breaking Cold Wave
    Broke Records back over 100 yrs. was $157.00 for Electric & Gas .
    $168. in 1 month , so Pay Back will be pretty Quick ..
    I Projected the 50 Gallon Hybrid Tank would be Paid in Full 3.5 Yrs. .
    All the Other Equipment and Electrical Up Grades to Home - Which Most Folks wouldn't Do
    Gas Line Up Grade - which Most folks Need Not do is still only 8 Yrs.
