Results 1 to 13 of 25
    Aug 2013
    Orange County CA
    What type of flaring tool is best for Mini splits
    I have been installing more and more mini splits this year. I have been putting a drop of clean vacuum pump oil on all my flares. What type of deburring tool do you guys use? Also what is the best flaring tool? I'm just trying to install leak free Mini splits.
    Aug 2011
    Have you checked out the spin-flair - goes into a drill don't need to deburring. Thinking yellow jacket is making simular spin-flair like tools. For deburring have you tried a unibit. Its tapered cone drills diferant size holes
    Tucson, Arizona
    Quote Originally Posted by Junior1983 View Post
    For deburring, I prefer the pencil type to the pyramid type, they seem to be smoother, although I have both.
    For the flaring tool I really like the orbital clutch type, I've been using the hilmor brand for the last few years with great results. And nylog also. The only other tip I have is using a torque wrench, I've found each manufacturer has a different torque requirement, just check the install manual, as it's different from the specs on website, for at least one brand. CPS makes a nice kit specifically for mini splits. Good luck with it.
    There are two ways to do things, Right and Again.
    Jan 2015
    Bellevue, Washington, United States
    Here's a video that I posted on youtube about this very subject:
    https://www.youtube.com/watch?v=cag7DUHIo0M
    Aug 2009
    Maine
    I have been using my SOG multi tool for deburring. I have the spin flare and it sucks. I also use the hilmor flaring tool. Often times I don't cut the tubing all the through and break it apart. No deburring needed. Always use Nylog.
    Quote Originally Posted by doug1111 View Post
    Athens, Ohio
    +1 on using a torque wrench.
    The tendency without one is to tighten too much on small tubing (1/4" and 3/8").
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  7. Likes doug1111 liked this post.
  8. #7
    Aug 2011
    Quote Originally Posted by lytning View Post
    Thanks for the info seen video on spin flair & spin swag, guess not as good as it looks,
  9. #8
    Feb 2015
    Ohio
    Hilmor makes a good flaring tool
  10. #9
    Mar 2014
    Yellow jacket makes a good one, get the one with the eccentric flaring cone and clutch and you should be all set
  11. #10
    May 2010
    Canada
    I have never seen the spin tools before.
    Id have to try the spin-flare before i would but it (unless it relatively cheap).
    The spin swage looks like somthing id be interested in......
  12. #11
    Feb 2015
    Ohio
    The spin flare 60241 from yellow jacket. It look interesting. Has any one tried to use it yet?
  13. #12
    Aug 2009
    Maine
    Hope it works better than the original. Those didn't work for crap.
    Quote Originally Posted by Doodlehvac View Post
  14. #13
    May 2010
    Mechanicsville, Virginia, United States
    Perfect every time.
  15. Likes skwoodwiva2 liked this post.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
