Results 14 to 20 of 20
    Jan 2015
    East Tenn
    OK, that sounds what's Happening , as it's very short 9-10 ft run , and down Hill about 5 ft.
    Our Windows aren't the Best even so Humidity shouldn't change that Fast - OK Thanks .. Guys
    It is 81 and 85% out side .. 72 Degrees & 59% Inside _ Just got done with Stage II and will be shut down for 3 hours ..
    Calling Tech ..
    Athens, Ohio
    Quote Originally Posted by QualityAssure View Post
    Calling Tech ..
    So you're doing what I advised in the first place and you criticized me for suggesting it?
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  3. Likes darctangent liked this post
  4. #16
    Jan 2015
    East Tenn
    OK - New Testing - I Lower the MRT on the Stat for _Stage 1 to 3 min. from 9 min.
    Raised the Stage 2 MRT to 11 min. from 8 min.
    This has lowed the Humidity another 5% During the Runs , but still the Lowest is 58%
    Outside Temp 78 Humidity 80% / Morning Temp 70 & Humidity 88%
  5. #17
    Jan 2015
    East Tenn
    Also - Why is it that when 2 Window Units are in the same Home they are pulling Humidity 12,000 BTU Unit and a 10,000 BTU Unit ..
    But First Stage on the XR17 doesn't seem to pull anything , even adds Moisture . It would be rated around 24,000 BTU's I Believe . .
    Sure doesn't Add Up ..
    Never got a High and Low Temp on Coil , Never got a Static Pressure Test , Never even did a Full Volume of the CFM -Supplied - Cal.
    Really more like a Shot in the Dark and lets see If that Works out alright .
    Guess I'll have to take this to them - Hard ..
  6. #18
    Because the 2 window units will have a colder coil temp then your 2 stage A/C has.
  7. #19
    Feb 2007
    Fremont, Indiana
    In first stage....... I hate two stage ac, horrible humidity control so why bother?
    I'm wondering if the op is keeping fan on? This will also be counterproductive in humidity control.
    Lock out 1+2 stages, fan on auto!
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
  8. #20
    Quote Originally Posted by kamersoutdoor View Post
    When sized right, and set up right. first stage will have a long enough run time to dehumidify. Just too many companies over size them. And claim because its 2 stage it doesn't matter/hurt.
