Results 1 to 13 of 28
    May 2011
    Pennsylvania, USA
    Roof Top Unit Condensate Drain Lines
    I have a few roof top units I have issues with condensate traps freezing and breaking over the winter. What do you guys do to prevent this issue?
    Jul 2015
    Bowmanville, ON
    Empty them on fall maintenance, prime them on spring start-up! I also stock some generic 3/4 pvc pipe and fittings to repair broken ones during routine maintenance. If your worried about odours and such being drawn in, I suppose you could prime the drain with a bit of antifreeze solution, or maybe a salt water brine to keep the environment happy but even then it can certainly still freeze on those real cold nights. I find the PVC even if not drained holds up pretty well for a few seasons freezing over.
    Southold, NY
    T in the bottom of the trap with a plug that's removed in the winter.
  4. Likes cburns liked this post.
  5. #4
    edmonds wa
    Drain it for the winter.
    UA Local 32 retired as of Jan 2020
  6. #5
    Mar 2010
    Arnold, Mo
    I believe Timebuilder recommends not gluing the pieces together. When they freeze, they'll just come apart.
    Sent from my SM-N910P using Tapatalk
  7. #6
    Sep 2003
    Use V-traps. Go vtraps.com
  8. #7
    Apr 2010
    Quote Originally Posted by yewbee View Post
    Got anymore info on that? Better pics of the inside?
  9. #8
    Sep 2003
    Vtraps
    Quote Originally Posted by CHAINIK View Post
    Go to their web site vtraps.com
  10. #9
    Apr 2010
    Right, got that. You already said that. Went there. Not much info. Don't sell them around here. Need better pictures. Unless you wanna send me a sample.
  11. #10
    Southeastern Pa
    Quote Originally Posted by flanders View Post
    That is correct.
    In addition, they are 100% cleanable, and if a part should crack due to UV damage from the sun, you just replace it.
    You can always tell when a resi guy has been on a roof. Glued traps with purple primer everywhere, and no easy way to clean them, either.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  12. #11
    Southeastern Pa
    Reasons not to:
    1) more expensive than PVC parts
    2) Every time the blower stops, it drains. Then, it has to re-prime.
    3) Some units using VFD's never stop the blower, so it could freeze in a sudden cold snap.
    Nice idea, but like many inventions, it is a solution in search of a problem.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  13. #12
    Sep 2003
    Quote Originally Posted by timebuilder View Post
    Reasons not to:
    It solved many problems for our customers. In use for over three years in the northeast and no problems.
  14. #13
    Apr 2014
    Wisconsin
    I personally build my traps out of 3/4 or 1" pvc. I don't glue any of the fittings together, this way they're easily cleanable and or repairable, and also if we do get a cold spell they will push apart instead of snapping.
    Some of the guys in our company like using the " EZ-Traps"
    While theyre nice and see thru and cleanable, i personally feel they're not the best because after a season or two, the clear part shatters from the UV breakdown.
    Hope this helps!
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
