Page 1 of 5 12345 LastLast
Results 1 to 13 of 54
    Jul 2015
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cleaning condensate pipes without applying pressure
    After finding unglued condensate pipes, and at other locations having to cut lines, I came up with this way of cleaning.
    After capping the vent-
    1. Take a 3/4"PVC tee and attach a foot of 3/4"pipe to one leg.
    2. Cut the other leg off at the TEE so it looks like an ELL with a hole in the side.
    3. Connect the base of the TEE to the end of the condensate line outside.
    4. Stick the end of an air gun with a 2" brass or copper tube screwed in place of the tip (since the tube is soft, no fancy threading is needed unless you want to build a tool) into the cut leg of the TEE.
    5. Wrap a rag around the opening between the gun tube and the tee to make a seal (this is the suction side).
    6. Apply air (or CO2, or nitrogen) pressure and the condensate and gunk is sucked from the pan and piping.
    Remember to uncap the vent since you are so excited by how easy this was, and the cool blast of water, and gunk which is now all over the side of the house.
    Yes, if you use a long enough brass tube you don't have to cut the tee.
    Yes, you could make a tool to do this.
    Yes, it won't work if you cannot find the end of the condensate drain.
    No, I don't have any pictures because I make one when I need one.
    Phoenix Arizona
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Or this...
    "If history repeats itself I am so getting a dinosaur"
    Jul 2005
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Cheers View Post
    Or you could buy a sludge sucker.
    Aug 2009
    Maine
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Clog Popper, even though I have the zoo gun.
    Apr 2010
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Shop vac at the outlet, if I couldn't blow it out with my mouth.
  6. Likes HVACdaddy91 liked this post.
  7. #6
    May 2011
    south florida
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can't picture what you're trying to describe. Especially adding air co2 or nitrogen, when the title said "without applying pressure."
  8. #7
    May 2014
    Bay Area California
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having some serious problems with your procedure. As per step #1, I've attached some PVC pipe to one of my legs. So far so good. But in step #2, you want me to cut off my other leg. Sorry dude, I just can't drink that Kool-Aid.
  9. #8
    Jul 2012
    Bridgeton, MO, 'burb of St. Louis, Mo
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Beer, you crack me up with your literalness.
    If thinking was easy,
    everyone would do it!
    Regarding Russian Roulette; five out of six players think it is a safe, enjoyable game!
    "And I've been banned twice. What of it? If you aren't getting banned once every 3 years, you aren't trying." Brian8383
    "it's actually 90 right now in this shaded area of satan's butthole." - HVAC_marc
    “Don't believe signature quotes.” - George Washington
  10. #9
    May 2014
    Bay Area California
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm thinking I should've been wearing pants when I duct taped that pipe to my leg.
    Quote Originally Posted by rc811002 View Post
  11. Likes davidj001 liked this post.
  12. #10
    Jul 2012
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by BBeerme View Post
    Gotta think ahead dude! Hairy legs and duct tape has got to suck! Did you use the good stuff? (Alum tape vs cloth)
  13. #11
    May 2014
    Bay Area California
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It was sticky enough to give me a wax. I don't know how the chicks do that. I am totally not into pain.
  14. #12
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try capping any vent and then using a shop vac on the outside end of the drain line. <g>
    PHM
    PHM
  15. #13
    Jul 2012
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PHM
    Sounds so much better than cutting a leg off....
