Results 1 to 7 of 7
    Apr 2015
    South Carolina
    problems with pre-rotation vanes actuator on yk chiller
    Has anybody had any problems with the PRV's on York YK chillers? I have had two go out because of
    gears locking up and the latest one to replace the last came in DOA. The field coil was open right out
    of the box. Chiller is only 5 years old.
    Dec 2014
    New Mexico
    Only problems that we have seen here were two that would not stop rotating at the close position. Very weird to stand there and see arm going around in circles. That was only on two out of 150 YKs. All way out of warranty .
    May 2015
    North NJ
    Sounds pretty uncommon.
    Nov 2019
    I have one now on the second actuator and about to replace that one as well. 5 years old
    Nov 2011
    East Side
    Are the actuator motors hitting their internal stops before the vane arm starts to bind?
    Aug 2019
    LA
    Yes. There was a bad batch that were failing often. Part numbers didn’t change so good luck
    Nov 2019
    They sent us another and like you said same part number. I guess we'll see. This machine has been checked top to bottom by Johnson and another chiller company. No solution. Running good again for now.
    Sent from my SM-N975U using Tapatalk
