Results 1 to 2 of 2
    Mar 2014
    Palatine, Illinois, United States
    Analyzer out of sync
    my yellowjacket analyzer high and low side are not synced up when I connect to a system that is under neutral pressure. Is this a common problem or is this normal. I also have problems getting the unit to shut off
    Mar 2009
    Minneapolis, MN
    Refrigeration System Analyzer
    Have you tried zeroing the pressures? On our latest software (version 1.11) we moved the power-off function to the system analyzer menu. A software update should correct your shut-off problem. Please call our tech support line if you need further assistance with either of these items at (800)769-8370. Thanks.
  3. Likes lytning liked this post
Tags for this Thread
