Results 1 to 2 of 2
    Apr 2015
    Confused Bryant Housewise T6-WEM01 High Humidity
    My contractor installed a Bryant Housewise T6-WEM01 almost 2 weeks ago. The humidity reads 30%, or more, above actual humidity. I have turned off the dehumidify setting repeatedly and it keeps getting turned back on at each schedule change. As a result, the room temp is always colder by 5 degrees. I contacted the contractor and he replaced the Homewise and I still have the same problem. He said he has 4 other customers with the same problem. Could this a problem with the install or could it be a bad batch of the Homewise controls?
    Jun 2015
    Did you ever get a resolution to this? I'm having the same issue.
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
