Results 1 to 13 of 27
    Mar 2015
    Hamersville, Ohio
    Possessed 3- Phase Compressor
    Greetings Ya'll,
    Has anyone had a 3-Phase compressor, that refused to run, when balanced 209 volts is present at T1, T2, & T3?
    This unit was not hot, not humming, not grounded to the chassis, not pulling any amps, & it also had continuity between all 3 terminals.
    Ohms between all 3 terminals was .028, which isn't correct, but, the comp exhibited no other problems!
    I switched T1, & T2, & "bumped" the compressor, & then rewired it to the correct terminals & then the compressor ran in with the proper rotation.
    And, it ran long enough to pull the Walk-in down to 41 degrees, before it quit again.
    Jun 2014
    Dover, DE
    When it quits what legs are opening? What's shell temp?
    Southeastern Pa
    I'm curious what is meant by "balanced" 209 volts?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Southeastern Pa
    And it sounds like a shorted or grounded winding(s).
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jun 2013
    N. Canada
    Overload protection ng?
    Handles the "AA" battery ma from your ohm meter.
    Finally makes half-arse connection to run for a while.
    Hope it's external type.
    Dec 2012
    columbus, OH
    All the funny thing i see with electrical issues that one wouldn't phase me (pun intended). Get em a new motor.
    Mar 2015
    Victoria, Texas, United States
    Does it trip the breaker?
    Stongsville Oh
    David! Are you out there, did you get amp draws, was it over amping and going off on internal overload or motor protector.
    ckartson
    I didn't write the book I just read it!
    Mar 2015
    Hamersville, Ohio
    Mornin'!
    I have to make this quick, as I've got paper work to do before getting out of here.
    A lot of you, need to reread my post, as you're asking questions, that have the answers uin the opening post.
    And yes, Core-d, I'm replacing the compressor as well as several other parts.
    This Service Station/Store could easily be turned into a Museum of what should not be done, in regards to HVAC/Refrigeration/ Electrical, & Plumbing
    Western Wa.
    Have you mega ohmed it? if so what are those readings? What kind of compressor?
    UA Proud
    "Phfft! Facts. You can use them to prove anything." Homer Simpson
    Jan 2010
    You said (first post) it showed no amps when not running ( no brainer here ) BUT you gave no amp reading after it started. 😮
    Southeastern Pa
    I still want to know what "balanced 209 volts" are...
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  13. Likes Scott Kline liked this post
  14. #13
    Jan 2010
    Quote Originally Posted by timebuilder View Post
    Well now, as you know, when one balances a load center they try to achieve equal AMP loads on all phases soooo..... could one do so with VOLTS 😕
  15. Likes Scott Kline liked this post
