Thread: Capitan's hook
    Jun 2009
    Ft Worth, Texas, United States
    Capitan's hook
    Yayy or nayy?
    May 2011
    Minnesota & Las Vegas, Nevada
    7-8 years ago one of the senior techs I worked with had this. He only used in really tight spots but he swore by it.
    "Quality is never an accident; it is always the result of intelligent effort. The bitterness of poor quality lingers long after the sweetness of low price is forgotten" --- John Ruskin
    Oct 2007
    Austin Texas
    Works pretty good for not burning the insulation out of a cabinet. Also on suction lines, you can heat the whole pipe up pretty evenly.
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
    New Mexico
    I have one similar but never really cared for it. Too much heat for one thing. The other is the solder follows the heat and I play the flame to run the silver where I want it to go.
    Might think I'm nuts until you try it but if I need a lot of heat I use my cutting head. I don't use the lever though. It acts like a big rose tip.
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
    Oct 2012
    Where we mow our own grass
    It works good for unsweating fittings.
    Its too difficult to braze with though, I just use a rosebud tip.
    Aug 2013
    S C
    Quote Originally Posted by hvacker View Post
    I learned to brass using a cutting head, most industrial maintenance people do to.
