    Jan 2015
    East Tenn
    2 Stage Thermostat - Memory Jogger needed
    Looking at the Set Up settings on a Trane 2 stage stat :
    The std 3 min Burn MRT and the MOT settings - under COMFORT SETTINGS in
    If I move to 9 Min. MRT on stage 1 the stage 2 runs longer also , seems it would have the
    Opposite Effect .
    INSTALLER SETTINGS :
    1. I get a longer burn time in stage 2 , when I increase the MRT in stage 1
    That Seems Off ?
    2. Looking into Customizing these setting - Manual refers to Z Off Set ( Referred to as Delta )
    Delta for the Life of Me can't recall - How does the Delta settings effect ( Burn Rate - Timing - ETC )
    Is Delta Designed to Kick Broad at Temp Differences Up or Down Or Including a Time Line amount ?
    Any Answer would be of Help ,
    Dan
    Jan 2015
    East Tenn
    Anyone setting up American std or Trane 100% variable 2 stage Stats ?
    I Just wonder what seems to be the Best Settings You have found or are using .
    I realize , Home Envelope means a lot and Sq. Ft , also Zip Code
    These have been around for awhile , But I have Never done one .
    Anyone got anything on XV95 Straight Gas settings - 2 Stage 100 % Variable . .
    Jan 2015
    East Tenn
    LOL - No One has any Idea on Efficient settings for a 2 stage Stat ?
