+ Reply to Thread
Thread: Insulation Sealer/Fungicide
    The very humid south
    Hey guys, I'm getting ready for a job where the customer wants the Supply and Return plenums sealed to keep the fiberglass insulation out of the air stream. Can't say I blame him, but what products are on the market for this? I know Foster has a line of products but which one should I use?
    Altmar, New York, United States
    are you talking about encapsulating it with spray foam or just sealing the seams with mastic?
    coating the inside of the plenums to keep the fiberglass insulation out of the air stream and also prevent mold growth. We seal all seams on the exterior with mastic....
    Mar 2013
    Treasure coast, FL
    wouldn't coating the inside of the duct essentially create another vapor barrier, potentially causing condensation on the inside of the ducts?
    Of course; I'm thinking like a Floridian, Ducts in the attic and used primarily for cooling. I guess it would be okay if the ducts are connected to a furnace.
    south louisiana
    why not change plenums & insulate them externally?
    I've done that for a customer with fiberglass issues.
    best of luck.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
