Results 14 to 18 of 18
Thread: Stupid Question
    Jun 2014
    Holly Springs, North Carolina, United States
    Quote Originally Posted by Mooshman812 View Post
    Thumgum or cork tape work ok as well If you press it in.
    I used to use thumb gum all the time but haven't seen it since I left Ohio 9 years ago. I've got a wad stuck to a shelf in my garage though, need to pull it out and stick it in my truck again.
    HVAC with Stephen Rardon
    Mar 2014
    Charlotte, nc
    Quote Originally Posted by shavedneon View Post
    I use the sharp end of the screw in the field, and about 120 psi air gun in the shop, cleans them perfectly, but I have lost a magnet from the blowgun
    I've been using a quarter inch by 2 screw since my days as a helper...easiest and no worry about blowing the magnet out of it.
    Sep 2014
    Dallas, Tx
    A little Double Bubble works fine but I can't bear to waste good gum so I dab a little duct mastic on it and let it dry. Usually pops out whole with the shavings stuck in the mastic.
    Dry as a bone Tucson
    Quote Originally Posted by Kraft Master View Post
    Frickin genius right here folks!
    Watchman Nee
    south louisiana
    agreed...going to try this myself!
