Page 1 of 4 1234 LastLast
Results 1 to 13 of 52
Thread: Pesto
    May 2014
    Bay Area California
    Pesto
    High quality pesto is almost impossible to find, and if you do, you'll have to pay an arm and a leg to get it. Classic pesto also has a cheese in it and pine nuts. For long term health reasons, I've cut back on over 90% of my normal dairy intake. And once the pine nuts jumped from 8 bucks per pound to over $30 per pound, they often go rancid before the consumer gets them. So I've substituted walnuts and you can't really tell the difference.
    Don't be afraid of the olive oil. I've been meaning to make a write up on basic health thingies, and if I can ever get that together, I'll post it here. Bottom line, there are health benefits to a good quality olive oil.
    Anyway, it is best to use the spring growth, but can be made anytime you get your hands on inexpensive basil. Remember, typically, when the price goes down, it is in season and will be fresher. Concentrated fresh basil as in this recipe will have almost a peppery flavor to it.
    You can use this for most anything. Dipping, fresh veggie stir fry (add after frying and just before plating), even on eggs.
    I don't have a food processor, only a blender. So if you have a food processor and know how to use it, that would probably be better.
    PESTO 7/12
    2 Cups yield
    The motivation or impetus for this recipe was the large bunches of basil for only a buck at our local farmers market in springtime. Depending on the season, to get the same amount, it would probably take three to five bunches from our local grocer at a greater cost per bunch. By the time I’m done removing the leaves from the bigger stems, I have a pretty full and well rounded mound of leaves covering most of a ~10” dinner plate.
    Regarding olive oil, I have found the Trader Joe’s Premium 100% Kalamata Extra Virgin one quart+ for $8.99 to be a great value and product. A good quality of olive oil will always enhance the flavor of any pesto recipe. You can spend (a lot?) more to get an inferior product, no need for the ultra high end oils; after all, this is about the fresh and intense ‘spicy’ basil flavor.
    One thing to take note of is that the flavors will blend and mellow after sitting overnight. This may seem obvious, but there is a bigger point . . . For example, as I was playing with the ratio of ingredients, one batch tasted too salty after making it; but was wonderful the next day. Even this recipe may taste of a bit too much salt and garlic after making it, but the next day that flavor will mellow and blend into something very yummy.
    Put into a blender:
    1 C Olive oil
    1.5 t Salt
    2 t Vinegar (preserves color)
    And loosely fill blender with basil leaves (to start) then pulse blender (no need for a lid).
    After pulsing the blender - - I do everything in this recipe with the blender on medium speed, top up blender with more leaves and pulse again. Keep pulsing. Add another small handful of basil, but start packing it in now. I pulse it a few times after each addition. Add more leaves as necessary, pack, and mix the blended and new leaves with spoon. Continue until no more leaves. Sometimes I add more oil. Don’t worry about adding too much oil, if the oil raises to the surface after a day or so, you can use it to flavor other cooking.
    After all basil is in blender, now add:
    6 Lrg Cloves garlic, peeled and quartered
    As garlic blends, you can slowly add:
    1 C Walnuts
    You will notice it getting thicker. The more walnuts you add, the slower you will need to add them. You may need to turn the blender off to “release” an occasional air bubble. I used to just stop adding the walnuts when it got thick, then I began measuring them and found a cup to be about what I was using. More or less is okay to adjust for consistency.
    Personally, I like to keep the blending to a minimum during this last stage. But I enjoy a more coarse texture. If you like it creamy smooth, blend it longer.
    New Mexico
    Pistachios are another good substitute for pine nuts. Here, people sell pine nuts on the road. A cash crop for them.
    Put a sheet under the tree and hit it with your pickup. The tree not the sheet.
    If someone doesn't like pesto it's usually because of cheap cheese. I only use Parmigiano Reggiano. Most others smell like gym shoes. And don't even consider the dried stuff. Boars Head and Murray's are good.
    I've been told hard cheese is not as bad as the soft cheeses. Don't ask me why but something to do with the cholesterol.
    Fresh basil is easy to grow even in a kitchen. I've got some Greek basil growing now I haven't tried yet.
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
    Desert Southwest
    It is a lot of work getting those nuts out of the cones and then there all that sap too.
    If you can't fix it with JB Weld, Duct Tape, and Ty Wire it has to be replaced.
    No good deed goes unpunished.
    If you want to take off friday to go fishing then make sure you train your helper right.
    New Mexico
    Quote Originally Posted by desert guy View Post
    Ya I know....You live here too...
    Not as bad though as black walnuts where, east of here, I used my truck to break the hulls.
    Sep 2015
    I also do my own Pesto at home and this is a hit for my family and friends.
    Phoenix Arizona
    I use olive oil, garlic, basil, pine nuts, and pecorino romano cheese. I get it all from Costco...I will substitute the basil for rosemary and add dice red bell pepper and use it as a stuffing for a pork loin that I butterfly a couple different ways stuff, roll, tie l, roast...
    Desert Southwest
    I am going to try and make some as I have a Mexican Basil and a regular Basil plant and both are huge.
    May 2014
    Bay Area California
    Sometimes the leaves from older plants later in the season [like now] won't make good pesto. The flavor just sort of falls flat or turns more bitter.
    Aug 2016
    Thanks for the recipe, gonna give this a try
    Mar 2017
    Thanks for sharing this recipe.
    Apr 2018
    Big thanks for the recipe!
    May 2014
    Bay Area California
    Today was the first day the fresh basil showed up at the farmers market. The best of the season. Just whoopped up my first batch of basil for the season. Must have been the beer, but I felt the urge to put in more garlic. BooYaa . . . A bit more zingy than usual !!
    I do a triple evac with nitro to remove non condensables.
    New Mexico
    Did y'all watch the report on olive oil on I think 60 Minutes some time ago. It talked about Italy dumping poor quality oil on the US markets largely because we didn't know any better. Selling slut oil for extra virgin. Fancy bottles disguise the quality. Some of these are priced at more than $30/bottle.
    Taste is about all you can do and never buy a bad one again. Some cooks have switched to other oils like safflower.
    I use mostly peanut oil for cooking. Has a good high smoke point and almost no taste. Some things just need the buttery quality of olive oil so if anyone knows a good one let us know.
