Results 14 to 26 of 57
    Southeastern Pa
    Amen.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Atlanta area
    Quote Originally Posted by Quick Carl View Post
    GW people are pointing the finger at us. You are too- under the guise of water management.
    Different song - same dance..
    Yeah, cuz like, water mismanagement isn't a real problem.
    Yeah, dude, you just want to point your finger at someone.
    You're pretty quick, Carl.
    Vacuum Technology:
    CRUD = Contamination Resulting in Undesirable Deposits.
    CRAPP = Contamination Resulting in Additional Partial Pressure.
    Change your vacuum pump oil now.
    Test. Testing, 1,2,3.
    Apr 2012
    Charlotte Area NC
    I blame water heaters...
    Sent from my van
    Jun 2013
    Austin, TX
    Quote Originally Posted by Space Racer View Post
    Following this line of thinking, the net result should be that aquifers and other groundwater resources are replenished. But this is not the case.
    Groundwater usage is increasing around the world. Most water is wasted. I think the net result is that fresh water becomes saltwater much faster than saltwater becomes fresh water.
    If we start desalinating more water, this problem can be diminished. Other countries depend on desalinated water as a major or primary source of fresh water. All we need to do is emulate them.
    Maybe the solution is to use salt water where fresh water isn't really necessary, such as flushing toilets? (Albeit probably only practical for commercial and apartment buildings, not individual houses.) The challenge of making all the plumbing corrosion resistant is a lot easier now that most of the pipes are plastic.
    Atlanta area
    Quote Originally Posted by NiHaoMike View Post
    Aha! What a great idea.
    Well, maybe not, on second thought.
    I wonder if water treatment facilities can handle salt water. And where would the salt water go from there? Back to the ocean?
    Vacuum Technology:
    Jan 2014
    Jacksonville, FL 32259
    Dude- you're the one pointing fingers. You blame drought and forest fires on lack of water management??
    And you dismiss the sun.
    Uuh, without the sun, there is no global warming at all. period..
    Space is very cold. Hot goes to cold very fast. Shut the sun off and everything dies.
    Then you'll probably suggest Ice management.
    Atlanta area
    I was mimicking you, not accusing you.
    Vacuum Technology:
    Jan 2014
    Atlanta area
    California considers rules for making seawater drinkable amid drought
    Water regulators in drought-stricken California on Wednesday were set to adopt new rules for desalination plants designed to make seawater drinkable in the latest effort to shore up water supplies as dry conditions stretch into a fourth year.
    http://news.yahoo.com/california-con...175150790.html
    Vacuum Technology:
    Southeastern Pa
    I think there is a lot of push back against desalination plants because the environmental lobby doesn't like how much electricity it takes to run them.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Atlanta area
    Sodium battery contains solution to water desalination
    http://www.gizmag.com/sodium-battery...ination/41683/
    Vacuum Technology:
    May 2009
    Jacksonville FL
    Funny how we are both scared of running out of water and rising sea levels at the same time.
  13. Likes kamersoutdoor liked this post.
  14. #26
    SE Michigan
    Engineer a plague (or war) to rid the world of a few billion people and you wont have to worry about water/distribution problems. Anything else is just kicking the can down the road.
    Humanity has reached an unsustainable point, be it food, the land to grow the food, and water.
