+ Reply to Thread
Thread: Sealed Ducts?
    Apr 2014
    Sealed Ducts?
    I sealed the registers in my apartment because I was waking up coughing and felt ill. I'm not going to turn on the A/C, but am wondering if air pressure will build up and cause problems? Thanks.
    Apr 2014
    Well you'll dead head the fan(s), which can cause an electrical overload, overheating, and if the conditions are right a fire. I'll grant you that's worst case, but your best option is to turn the unit off entirely, either at the thermostat or a breaker, though this can cause problems in the refrigerant loop if left off for too long.
    That's the "best option" in terms of stopping air flow, the BEST option is to (a) visit a doctor and find out why you are feeling ill, or (b) get the air quality in your home tested. I don't know where you live, but around here living without AC just isn't an option. If your landlord is a merciful ruler, you may be able to take your concerns to them, and get something done about it.
    Apr 2014
    Dead Head
    Quote Originally Posted by ba12348 View Post
    Thanks, what does 'dead head' mean?
    Desert Southwest
    Dead Head basically is running the fan with nowhere for the fan to push the air to which builds up the static pressure in the duct forcing the fan to work harder.
    Check your air filter and replace it if it is very dirty. I live in a dusty enviornment so I replace them each month with an inexpensive pleated one from Home Depot.
    They are about $8 and change for three of them.
    I would also take a screwdriver and remove a register and see how dirty/dusty it is in the duct.
    How old is the apartment building?
    If you can't fix it with JB Weld, Duct Tape, and Ty Wire it has to be replaced.
    No good deed goes unpunished.
    If you want to take off friday to go fishing then make sure you train your helper right.
    May 2014
    I agree with desert guy pull a couple of registers and see how dirty they are I live in the desert and most houses have evaporative coolers which really dirties up ductwork the company i work for offers duct cleaning service of which our machine does pretty good at cleaning them and then we fog the ductwork with an anti-microbial mist but it is also a good possibility that the ducts were not sealed when installed especially if it is an older building i have worked on numerous re-ducting jobs over the last year that I have been an installer and most were sealed with duct tape or not at all and if they are not sealed not only would you get attic dust in them but your efficiency goes out the window
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
  • You may post new threads
  • You may post replies
