Results 1 to 7 of 7
    Intermatic Wall Timer Sparks, Trips Breaker
    I have an Intermatic wall timer, model 885L that controls a single heat lamp in a bathroom. The house and timer (20 amp rating) are about 32 years old. Tonight while switching on the timer, a spark shot out of the wall and (fortunately) the breaker tripped before anything else happened.
    Are there any known problems with these timers? I can have it easily replaced, but it gives me an uneasy feeling that this happened. I'm curious why something would work fine for years and suddenly fail like that. If it is a timer issue, I will have others in my house replaced too.
    Kudos to the circuit breaker designer, it may have prevented Intermatic from starting a fire!
    Jun 2013
    N. Canada
    Quote Originally Posted by skeletor View Post
    I'd be cking for a grnded/shorted heater before blaming the timer!
    (last closure in ckt gets the arc)
    Mar 2014
    Altoona, Pennsylvania
    I agree IRBH! Check to see if it is grounded out some where. Sparks to shot out in my opinion is an indication of a short.
    Dec 2014
    This all information for intermatic wall timer sparks while switching on the timer, a spark shot out of the wall and (fortunately) the breaker tripped before anything else happened.
    My Uncle lost his entire house to an old defective bath heatlamp, it started a smoldering fire in the attic, after his morning shower. When the sun hit the roof, air started moving and that's all it took.
    Athens, Ohio
    Install a 20 amp switch and measure the load on the heater. If it is within limits, replace the timer.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    edmonds wa
    At that age i am surprised it still worked.
    UA Local 32 retired as of Jan 2020
