Page 1 of 5 12345 LastLast
Results 1 to 13 of 56
    New England
    Navien Boiler install
    Navien Boiler install, not 100% done but pretty close. Name:  ImageUploadedByTapatalk1393163373.557746.jpg
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
    Cincinnati, Oh
    Primary pump built into the boiler?
    "Just get it done son."
    Dad adjusted
    New England
    Yes
    Cincinnati, Oh
    Quote Originally Posted by alliedtech12887 View Post
    Yes
    Looks good, looks good.
    Only thing I suggest, is:
    http://www.caleffi.us/caleffi/en_US/....jsp/index.sdo
    It doesn't actually matter, but when you go to change out that expansion tank, you'll thank yourself that you can isolate the tank from the system.
    If something like that is expensive, hard to get, whatever, a ball valve works just the same. You just use less fittings with the caleffi valve.
    I see 2 pipes sticking up on the right, coming off the bottom of the boiler.
    I assume thats for an indirect? If so, cool stuff.
    Dad adjusted
    Apr 2013
    NJ
    Combi Boiler the two pipes are for Domestic hot water. These boilers are really nice and do a great job keeping up with both heat and hot water at the same time. Can't wait put mine in.
    central jersey
    I don't see where you are draining the condensate, other wise looks very good nice and clean
    New England
    Quote Originally Posted by dodge View Post
    Yea here's the finished product. Name:  ImageUploadedByTapatalk1393782561.590824.jpg
    Sep 2012
    thomaston, ct
    Need neutralizer on condensate. Also better to pipe feed into navien provision for it on the right side. Automatically shuts off feed if boiler feeds for more than 7 minutes. Technically don't need the pressure reducing valve but we use them too.
    We usually dump condensate thru neutralizer and then into pump and send it away.
    Sep 2012
    thomaston, ct
    I'd also look into the webstone ISO kits or the navien manifold makes piping and servicing them way simpler.
    Sep 2012
    thomaston, ct
    O
    New England
    Quote Originally Posted by jlanesey View Post
    I've used the the navien header beside, not really a fan of it plus it didn't really fit this application.
    Sep 2012
    thomaston, ct
    Nice work anyways pro press looks slick.
    Sep 2012
    thomaston, ct
    Only thing I don't like is that drain
