Results 1 to 9 of 9
    Feb 2014
    Fan but no flame
    I have a gas log fireplace with a switch on the wall that ignites the fire from a pilot light. The problem is, if I want to use my blower, I have to plug the blower into a metal box receptacle located in the service area under the fireplace, and then unplug it to shut in off. Since this wasn't very handy, I ran a 14-2 romex wire from the receptacle box to the flame switch box and wired it as an extension of the black wire to switch the blower on and off. I used a duplex switch so that I didn't have to change out the wall box to accommodate 2 separate switches. I think this is where I screwed up. I first tried the top switch for the flame. It started up and went out as it should. I turned on the bottom switch for the blower and it also started up and shut down as it should. But when I turned them on together, there was a small flash of fire and then nothing. The blower continued to run but the fire would not start.
    Since the duplex switch shares a ground with both switches, could this have caused the problem? Also, I'm not sure what I now need to replace.
    Thanks for your help!
    bbones77
    In a machine room
    I think you want an electrician or a fireplace professional.
    Preferably before the house burns down.
    May 2008
    Missouri
    I second chuck's suggestion...
    Feb 2014
    So would you say I need to replace the gas valve? I already know what the electrical problem is.
    Anchorage Alaska / Seattle WA
    "But when I turned them on together, there was a small flash of fire and then nothing."
    I have had that same experience.... sometimes its just some smoke and no fire at alll..... but either way it generally means a trip to the supply house.....
    For the Government to Give Something to you - THEY HAVE TO TAKE IT WAY FROM SOMEONE ELSE FIRST...
    Apr 2006
    Barrie Ontario
    Why in the world did you go to all that trouble a pro would be able to set the fan with a thermostatic switch so it would come on when it's hot and shut off when cold. No need for plugging in and unplugging talk about an over complication
    May 2008
    Missouri
    We are forbidden to assist with DIY repairs. Site forbids it. Sorry.
    Feb 2014
    What a worthless forum. Please ban me so I never make the mistake of coming here again!
    Oct 2006
    The Beach
    Don't get so upset. We will try to help you but we don't want you to burn your house down.
    Blue Fox
