    May 2013
    lg ductless split heat pump
    i have a lg ductless split m/n lmn126hvi that stays on no matter the temp setting on the remote. The only way to shut it off is to take it out of heating mode. Thermistor? board? Any input would help thanks. I don't have time to properly trouble shoot this.
    Apr 2011
    SE Washington
    the ONLY way to fix it is to follow proper ts, get the service manual and youll be good
    Jan 2005
    I have changed probably a hundred thermistor's on LG equipment. It's probably your indoor air thermistor. That's where I would start at least.
    Jan 2005
    Here is a air thermistor chart.
    May 2013
    thank you. I appreciate your help!
