+ Reply to Thread
Results 1 to 20 of 48
Thread: Turbo torch
    Feb 2013
    In a house with windows and doors on it.
    Turbo torch
    Any good? Turbo torch MC kit, saw this at supply house Friday.
Size:  59.5 KBName:  uploadfromtaptalk1390162893111.jpg
    Sent from my VS980 4G using Tapatalk
    May 2011
    Ontario, OR
    I've been using a turbo torch now for 18 years. I am on my second one, and wouldn't think of using anything else.
    Feb 2013
    Have you saved on the cost of not buying oxygen
    Aug 2009
    Maine
    I have both. There are times when a turbo just won't do it. Many times it is better to use oxy acct and do it quick.
    Quote Originally Posted by mr.charles View Post
    May 2011
    Ontario, OR
    I haven't worried about the operating costs, I just wanted the simple ease of only carrying 1 bottle around. I have a brand new Oxy Acct system that has been sitting in my shop now for a couple of years unused. I have just never found a situation that the Turbo Torch couldn't do. Now the exclaimer is that I do mainly residential, and light commercial. The largest pipe I weld is 1-1/8, and so far I haven't noticed a problem with speed.
    Feb 2013
    Quote Originally Posted by Baloo2327 View Post
    I do mainly and light commercial as well, i believe this should work fine for resi. applications, that small of copper line shouldn't have a problem. is it true that you CANT burn fittings or pipe with the turbo torch?
    May 2011
    Ontario, OR
    Yes, but that doesn't mean that you can't screw them up. As with any skill, practice, and more practice. Remember, if everything was idiot proof, there would be no need for Skilled Craftsmen.
    Jan 2014
    For repairs in tight places or if you leave the doors on in a new install it SUCKS!! Oxy/act the only way to go
    Feb 2013
    What u mean leave the doors on
    Jan 2005
    steeler nation
    i have used a mc adapter for years. who wants do drag a big tank up a ladder for a couple joints.
    i also use mapp and axc ox.
    looks like the guy in the pic is holding the tip while it s firing. i have a few turbo torch tattoo's. what type of torch is that ? does it have a ignitor ?
    IV IV IX
    use your head for something other than a hat rack.......Gerry
    We have freedom because somebody fought for it.
    We keep it because we are willing to fight for it.
    We lose it because we are not willing to fight for it.
    Jan 2014
    Alot of people leave the doors on the a/h to solder the lineset if it doesn't have a txv. I always take them off regardless but if you don't the turbo will melt the paint off. The first install I was on we were doing a church that had trane 7.5 and 10 ton A/h and the tech was trying his best with the turbo and had all the rafters burnt above the units, not to mention multiple leaks 1 3/8 hard drawn is hell on a turbo
    Feb 2013
    MC kit he held the tip it never got hot
    Jan 2014
    Not getting hot is pretty common with a turbo.
  14. Likes mr.charles liked this post.
  15. #14
    Feb 2013
    Lol Lol I get it
  16. #15
    Apr 2003
    Greenback, Tennessee
    I have a turbo torch MC and an ox act torch on my truck. I do mostly resi work and a little light commercial. I prefer the turbo torch for most of what I do because its a whole lot lighter and the results are the same for most applications. Sometimes the extra heat of the ox act is advantageous, and for those situations, I use the ox act.
    A lot of techs here like to bash the turbo torch claiming that using one to replace a txv or reversing valve will result in burning up those parts. I have changed more reversing valves and txv's with a turbo torch then I can remember and I have never burned one up. For those that have I'm here to tell you that the fault lies not with the tool.
    -Marty
  17. #16
    Jan 2014
    I've never burnt a thing with them because I refuse to use them since 2000. Why waste the space on the truck . Oxy/act will do everything .
  18. #17
    Apr 2003
    Quote Originally Posted by HvacSpecialist View Post
    To answer your question because if I am changing a coil in an attic that only requires sweating one 5/8" pipe, I would like to save myself the trouble of dragging a Oxy/act rig through the attic when a simple mc turbo will do just as good of a job. I like to work smart rather then hard. Since you have Oxy/act on your truck, you already have a mc tank. The turbo torch less tank takes very little room on the truck.
    For resi work either will do just fine. Use whichever you prefer.
    -Marty
  19. #18
    Mar 2013
    East Concord, NY
    Heat something with it, spread the flame. It WILL get hot. OR...
    Ask him to hold the tip while you braze a 1" fitting with it... then show me the picture...
    Nest is POO!!
  20. #19
    Oct 2005
    Pacific Northwest
    Quote Originally Posted by m singer View Post
    I completely agree. I'd much rather use the turbo torch on a RV. 7/8" and smaller.
  21. #20
    Jan 2014
    what size tip are you uselhg to get 1 1/8?
    [QUOTE=Baloo2327;17505871]I haven't worried about the operating costs, I just wanted the simple ease of only carrying 1 bottle around. I have a brand new Oxy Acct system that has been sitting in my shop now for a couple of years unused. I have just never found a situation that the Turbo Torch couldn't do. Now the exclaimer is that I do mainly residential, and light commercial. The largest pipe I weld is 1-1/8, and so far I haven't noticed a problem with speed.[/QUOTE
    Id B exclaiming too if I could get 1 an eighth inch BRAZE jolnT S with a standard turbo torch tip.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
