Page 5 of 5 FirstFirst 12345
Results 81 to 96 of 96
Thread: Compressor upper cover inflation !!!!!!!!!!!!
  1. #81
    Mar 2013
    Treasure coast, FL
    Quote Originally Posted by KB Cool View Post
    This is one of those "one in a million" things! Like the time i cut a LLFD out of a system. Put it to my lips, blew and it becomes a fire ball! I guess the oil ignited from the little bit of oxygen i exhaled!
    You put a filter drier to your lips?
    Gross.
    Sent from my DROID BIONIC using Tapatalk
  2. #82
    Phoenix,AZ
    Quote Originally Posted by shellkamp View Post
    Gross.
    Yeah, i like to see if they were clogged.
  3. #83
    Mar 2013
    Treasure coast, FL
    Okay, and I'm not questioning your methods (just judging them not so silently), and I'm sure it costs more to do it this way, but couldn't you cut the outgoing side off first, then shoot some nitrogen through the liquid line service valve?
  4. #84
    Apr 2012
    Louisiana
    Heh, I've done that before. I use my hand kinda like a coupling. Wash hand and blow through fist.
  5. #85
    Phoenix,AZ
    What is that going to do? I'm looking for resistance! Also i would rather blow through some copper than wash my hands in a public restroom only to grab the nasty door handle on the way out!
  6. #86
    Mar 2013
    Treasure coast, FL
    Okay, your selective germaphobia wins this argument.
    Do you blow into new, known unblocked filter driers to compare resistance?
    How do you determine if you have a blocked cap tube for that matter?
    I'm just yankin' your chain at this point, ignore me.
  7. #87
    Jan 2014
    I've tryed to reply to this crrrrazy topic with nada luck sooo good luck blowing filters ..ps don't hurt yourself
    - - - Updated - - -
    ahhh oh now it works
  8. #88
    Jan 2014
    PLEASE no more paint thinner!!! I pooped from laughing.. compressor flash-expand and went out.. acid in system react w/paint thinner...your lucky.. cover inflate due to path of least resestance .. try denatured alcohol flush
  9. #89
    Phoenix,AZ
    An unblocked LLFD is like blowing through a straight piece of pipe. No resistance at all! Try it sometime! Just be careful of the flash fire!
  10. #90
    Jan 2014
    I'm having a very hard time wrapping my head around paint thinner, wow... That's the beginning of a soon to be dead compressor.. I know desperate times call for desperate measures sometimes but properly addressing a burnout compressor can never be replaced with paint thinner.. Just saying
  11. #91
    And you know this . . . how?
    PHM
    Quote Originally Posted by WilliamJRowley View Post
    PHM
  12. #92
    Mar 2013
    Treasure coast, FL
    Clearly the paint thinner did it's job and thinned the paint on top of the compressor, making it bubble. Causing the appearance of shell inflation. It's all an optical illusion.
    Paint thinner couldn't possibly work because it's not labeled for use in HVAC equipment. Otherwise it would be labeled "HVAC Thinner". Maybe even "flush" by a cocksure marketing company.
    That's how everybody KNOWS it caused a catastrophic failure.
    It's like when you hear Willie Nelson gets arrested, everyone automatically assumes it's for possession of pot.
  13. #93
    But "a paint thinner explosion" is completely inconsistent with the facts as presented.
    After the paint thinner was used for flushing the system (the not compressor) - the system and compressor were evacuated to well below the flash point of paint thinner, charged with refrigerant, and then operated - with the compressor pumping refrigerant. After some period of that operation the refrigerant was removed, the compressor removed from the system, and operated repeatedly pumping air against a closed suction port.
    You conclusion is inconsistent with the above. How could paint thinner have survived the above process and then only afterwards caused an explosion?
    PHM
    PHM
  14. #94
    Mar 2013
    Treasure coast, FL
    I forgot to add my <g> at the end of my monologue.
    I'm with you on the paint thinner.
  15. #95
    Aug 2012
    Iraq
    so soory forbeing late anweer
    from now i will never use paint htinner for flushing the system
    iw ill use only R11 REFRIGERANT
    WHICH IS 30 lbs =115 DOLLAR
  16. #96
    Aug 2012
    Iraq
    My only explanation is the protection provided to you by a gracious and benevolent God. I would fully expect the terminals or the discharge line to blow out before the compressor shell distorted.
    PHM
    U R RIGHT
    ITS THE protectection of gracious Allah
