Goodman heat pump defrost problem
Goodman Model VSZ130630.
Won't go into defrost. I shorted test pins on board. Compressor and Fan stop. Compressor comes back on but fan does not. Changed board. Same problem. Any ideas?
Originally Posted by
ralph
Is it running in defrost mode when it comes back on?
"Just get it done son."
Dad adjusted
Is that the model that does the quiet shift into defrost.
Sounds like quiet shift defrost to me. How long are you waiting for the fan to energize?
In will not come back on at all. The compressor is off for about 30 seconds. I don't think reversing value shifts, but fan never does come back on.
You did not wait long enough...
It is the job of thinking people not to be on the side of the executioners.
~Albert Camus
May take 14 minutes before it will come out of defrost. the compressor will stop again, and then the compressor and fan will both start.
I suggest keep a cheap stopwatch. When waiting for something to happen, time goes by slow and i have found that this keeps me on track while waiting. Does not seem to take as long waiting.
Sent from my DROID RAZR using Tapatalk
Post Likes - 1 Likes, 0 Dislikes
why would the fan stop when the unit goes into defrost in the test mode??
to build heat for defrosting the coil.
ralph
I meant compressor, not fan. sorry
Sounds like maybe defrost sensor
ralph
Quiet shift into defrost.
Well then like was said maybe didn't wait long enough? Do u know anything bout buderus GB142
Dennis-2
lol, what?
That defrost cycle is normal.
Dad adjusted
Dennis-2
Not really.
No quiet shift! I'm dumb but I idn't stupid
Dennis-2
Are you sure it doesn't have quiet shift.
If it doesn't, what have you checked with a meter.
Sounds like a proper "quiet defrost" to me.
Sent from my SPH-L720 using Tapatalk
