Originally Posted by
hvac_superman
You post total bull crap and expect us to believe it and then make us out to be the bad guy.
Look at the space between the pan and the insulation that you mounted your little miracle to, different size gap. Leads you to believe it is a different unit. Where did the pipe go that is in the way of the clean shot vs the shot of the dirty pan. The drain must be totally plugged up cause there isn't even a dimple or any indication of that drain hole. Don't make me count the coils of the heat strip, just take your lumps and don't try to BS us. Most of us have better things to do.
