Results 1 to 13 of 15
    temperature alarm for walk-in cooler/freezer
    last week we lost a lot food products due to the temperature rise inside the cooler and freezer box. the reason was the circuit breaker went bad, both freezer and cooler are in one circuit. is there any product out in the market sells an alarm that goes directly to the beeper or telephone system? thanks for the input.
  2. Likes JAYGRAV liked this post
  3. #2
    Boise Idaho
    yes, not sure of the brand but we installed them in rite-aids as a part of the energy management ccd panels. talk to your refrigeration contractor, the cost of a temp alarm is cheap compared to loosing all your food.
    matt
  4. #3
    manitowoc wisconsin
    Call your existing alarm company & have it added/monitored.
    False alarms from bubba blocking the door open during stocking should be expected.
    Take your time & do it right!
  5. #4
    Quote Originally Posted by Amfil View Post
    There are lots companies making products for what you are looking to do
    http://www.temperatureguard.com/vm503.htm check out that link
    I have never used this particular product but it claims to do what you want it to, if i were you Ild ask my regular refrigeration guy to set me up with something.
    What you want done you should have done by a professional
  6. #5
    Apr 2004
    I've used Sensaphone panels in computer rooms...they might go down to freezer temps. http://www.sensaphone.com/index.html
  7. #6
    Jan 2006
    thermo-simple...... can be a direct replacement for 2" dial thermometer or solar digital. Can be wired or wireless with EMS controller interface or simple dry contact alarm, or dial out device for voice or pager.
  8. #7
    Sep 2006
    look at this one
    the best temperature alarm for walk-in
    http://www.americancontroller.com
    https://youtu.be/5WlFwmX6_5w?t=3
  9. #8
    Mar 2015
    Medford, N.Y.
    What caused the breaker to trip? What size box/comp do you have? Are there separate breakers for each comp at each cond unit? If both comps start at the same time,that might/could trip the main breaker.
  10. #9
    Southold, NY
    Quote Originally Posted by njaircond View Post
    look at this one
    njair
    i hope after almost 9 years the issue has been resolved.
    07-16-2007, 09:01 PM #1
    Amfil
  11. #10
    Sep 2006
    The best temperature we install is from American controller in New Jersey this unit is not only refrigerator and freezer alarm it is support 16 sensor this enough for mini market it have LCD displayed that show you the temperature on each sensor you can easily rename the sensor from the website using Smart phone or computer.
    the wire connection is in bus configuration so one wire is support all the sensors
    This can be Great early problem addiction in commercial refrigerator by installing the censor on the line set and measure the temperature http://www.americancontroller.com
  12. #11
    Sep 2006
    yes American controller make very good one and easy-to-use you don't need to be programmer Genius to set it up the can do it for you or show you how to do it
    APS10 can support 16 sensor
    this i the web site
    https://youtu.be/PRp6j__Qblk?t=5
  13. #12
    Apr 2005
    Australia : Queensland
    http://www.carel.com/documents/10191...3D?version=1.0
    Carel also complies with HACCP for Food Safety Laws.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
  14. Likes JAYGRAV liked this post
  15. #13
    Feb 2016
    N'awlins Dawlin' USA and Palmares Costa Rica
    tempalert.com
  16. Likes JAYGRAV liked this post
