Page 1 of 6 123456 LastLast
Results 1 to 13 of 76
    Dec 2010
    San Bernardino, CA
    Trane Centravac Overhaul
    I have a customer that has 2 CVHE050's it has the two stage economizer I think that's the CVHE. They were installed in the mid 90's and have not been overhauled. I just did a leak inspection and found 20+ leaks a piece. Auto purger is running 30+ minutes ever 24. We had Trane come in to quote a repair and it was more then they anticipated. I've been looking into doing the work myself. The motor alone is in the 10's of thousands. They are running normal amperage and no excessive heat or noise. I want to try and overhaul it with leaving the old motor replace the volut/shell and gaskets. Has anyone on here performed this task and have a parts list and an approximate time frame to complete this. I cannot find a manual with overhaul layout and the local Trane supplier found some things but wasn't extremely helpful. Any input would be extremely helpful.
    Jun 2013
    Canada
    I have two 400 ton Trane Centravac Chillers, I have all the maintenance manuals and break down manuals, with pressure readings. This system was installed in the late 50s early 60s. Do you think this will help? I would have to scan them as the manuals are old school but very in depth.
    ottawa canada
    Have you even considered the amount of work involved and the specialty tools/rigging equipment you need to overhaul a Centravac .
    Do you have the nessacary recovery equipment to even remove the refrigerant .
    That chiller cost a whole pile of $'s , have you considered what /who is responsible if you do it wrong and you push the start button and it scrambles ??
    I am in the process of completing my 70th teardown and I still get butterflies and parts of me still pucker a little when I push the start button for the first time after completion .
    This isnt a job that someone with a pick up truck and set of reefer gauges should even consider attempting .JMHO
    Jun 2013
    Canada
    Its R11, 4,160 volts two redundant systems side by side.
    ottawa canada
    Quote Originally Posted by RACMT View Post
    The chillers you have are more than likely not the model the OP is refering to if they were installed in the late 50s early 60s .
    Jun 2013
    Canada
    I dont think butterflies can explain the feeling. Because it will either work or it will tear itself apart. Hopefully you are insured or have a lot of spare part and weeks of time.
    Jul 2013
    Atlanta, GA
    Not a task you want to take on without an experienced hand. There's alot more to it than replacing o-rings and gaskets. It's a very precise and complex process but even more, it's very dangerous without the proper rigging and understanding of the weights involved. The motor alone on a 4160, 500 ton centravac is close to 3000 lbs. Hope you have good insurance.
    Dec 2010
    San Bernardino, CA
    I don't have a pickup truck I work for a large industrial service company. If it's that much headache then I won't try and quote it, I know it's been done before I'm trying to determine the best way of going about it. My post was in a rush and I might have come off as a slouch to you. I've done service and maintenance for quite sometime I just have not been asked about an overhaul. I wanted to upgrade to the UCP2 interface and upgrade the panel with a modern liquid cooled VFD. The people I talked to at Trane said the volut it's self comes as a complete assembly and as long as the alignment is good and the gaskets are replaced it shouldn't cause to much of a headache. Torquing bolts, replacing gaskets and cleaning parts are primarily what's involved.
    Dec 2010
    San Bernardino, CA
    It is not 4,160 volt it's a rather small centrifugal. Sorry for the misconception I left the info on my iPad and I'm not at home at the moment.
    Quote Originally Posted by whiteside2831 View Post
    ...Torquing bolts, replacing gaskets and cleaning parts are primarily what's involved...
    that is what the apprentice does. is overhauling the chiller hard? not really...if you are trained properly. by my 4th chiller, i was overhauling them as the lead...but i also worked for trane at the time and i was trained by some pretty good guys.
    upgrading to the UCP2 isn't too tough except that the UCP2 upgrade hasn't been available for quite some time. you have to upgrade to the ch530 at a minimum and that may not be available any longer either (i am not sure). you may have to upgrade to the adaptiview which has to be perfromed by trane.
    as for adding a drive to the chiller...this aint no water pump. you will have to upgrade the controls in order to use a drive and there is a whole mess of things to consider before you spend that kind of money. using a drive on a chiller is much more than just slowing it down (because in many cases it won't slow down).
    "Right" is not the same as "Wise".
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by Healey Nut View Post
    I couldn't agree more!!!! And I quit counting overhauls a while back....I'd give this a lot of thought before proceeding on your current path, if I were you.
    I do have a question: You have 20 + leaks on one machine and only have 30 minutes/day pumpout time? Those numbers don't add up, partner. Are they mostly on the high side? That much pumpout time for low side leaks on an old machine isn't exactly grounds for the expense of a regasket, in my opinion (and no, I'm not an advocate of leaving something leaking, but the sky ain't exactly falling here). If you have evidence of the need for new bearings, that's a different story.
    Dec 2010
    San Bernardino, CA
    You guys are giving me good information. I didn't say I was going to do it, I'm trying to determine if my company and I are capable of handling the situation. We all learn at some point in time. I was told it was called upc2 but adaptview is what I was talking about. I'm trying to learn as much as I can. Obviously looking at it doesn't do the task justice. People that assemble cars don't rebuild them. I'm not trying to make an ass of myself, even though I appear to be doing a great job. Just trying to make the right call. That's why I'm asking, I wanted to see what information you fellow techs had on the procedure.
    Dec 2010
    San Bernardino, CA
    It's purge limit is set at 30. The on site mechanic resets it. It will trip a few times a day depending on run time. They are using a lot of free cooling so at the moment they are off and the auto purger still runs quite a bit.
