Results 1 to 9 of 9
    Aug 2012
    Iraq
    air conditioner name plate codes definition
    hi
    i saw codes on air conditioner name plate which i didnt understanbd it
    T1 cooling
    T3 cooling
    On the water but near the hood
    t1 is rated at a lower ambient than t3. Similar to EER/SEER.
    Aug 2012
    Iraq
    so do u mean that
    the air condtioner will work with higher capacity at t1
    and lower at t3
    Aug 2009
    Jurupa Valley, CA
    It coincides with the "Climate Type" up above. Basically, I think it's some defined outside condition ranges.
    Aug 2012
    Iraq
    ok
    why the capacity in T1 =18000 btu
    and in T3 = 15000
    Aug 2009
    Jurupa Valley, CA
    Because when it is hotter outside, it can't move as much heat.
    Aug 2012
    Iraq
    thank u pal
    Aug 2013
    T1 = 109.4F
    T2 = 95F
    T3 = 125.6F
    Aug 2012
    Iraq
    thank u
