    New Hampsha'!!!
    Infocon ASD driver export tags not working
    I am using the Infocon ASD driver and trying to use export tags. Setting any export tags in the ASD network provides me with naming errors below. If i set up a point under the lon network or bacnet network then the join works with no issues, it is only under the asd network does the join fail. Even if i add a numeric writable or any native niagara point with a point tag it fails, Any thoughts?
    Success [10:15:26 12-Aug-13] Starting Subordinate Join Job
    Success [10:15:26 12-Aug-13] Found default user: setup
    Success [10:15:26 12-Aug-13] Found Supervisor Niagara Station: WEBS_Riverwoods
    Success [10:15:28 12-Aug-13] Made Connection to WEBS_Riverwoods: ip:192.168.0.64 (1911)
    Success [10:15:28 12-Aug-13] Launched Supervisor-side Join
    Success [10:15:28 12-Aug-13] Tracking Supervisor-side Join
    Success [10:15:37 12-Aug-13] Supervisor: Launched Supervisor Join Job
    Success [10:15:37 12-Aug-13] Supervisor: Found existing Station: /Drivers/NiagaraNetwork/Woods_1
    Success [10:15:37 12-Aug-13] Supervisor: Using existing Station user and connection information
    Message [10:15:37 12-Aug-13] Supervisor: Attempting Subordinate Connection: ip:192.168.0.78 (1911) (Fox SSL: false)
    Success [10:15:38 12-Aug-13] Supervisor: Made Connection: Woods_1
    Success [10:15:38 12-Aug-13] Supervisor: Moved Station: /Drivers/NiagaraNetwork/Riverwoods$20at$20Exeter/Woods_1
    Success [10:15:38 12-Aug-13] Supervisor: Merged Station: /Drivers/NiagaraNetwork/Riverwoods$20at$20Exeter/Woods_1
    Failed [10:15:39 12-Aug-13] Supervisor: Job Failed
    javax.baja.naming.UnresolvedException: /Drivers/AsdNetwork/MechanicalSystems/CHWS/points/NumericWritable/PointTag
    at javax.baja.naming.BSlotScheme.resolve(BSlotScheme. java:188)
    at javax.baja.naming.BOrd.resolve(BOrd.java:266)
    at javax.baja.naming.BOrd.resolve(BOrd.java:228)
    at javax.baja.naming.BOrd.get(BOrd.java:204)
    at com.tridium.fox.sys.broker.BFoxComponentSpace.load ByHandle(BFoxComponentSpace.java:101)
    at javax.baja.sync.BProxyComponentSpace.findByHandle( BProxyComponentSpace.java:72)
    at javax.baja.space.BComponentSpace.findByHandle(BCom ponentSpace.java:509)
    at javax.baja.space.BComponentSpace.resolveByHandle(B ComponentSpace.java:538)
    at javax.baja.space.BHandleScheme.resolve(BHandleSche me.java:71)
    at javax.baja.naming.BatchResolve.resolve(BatchResolv e.java:178)
    at javax.baja.naming.BatchResolve.resolve(BatchResolv e.java:150)
    at com.tridium.exporttags.BSupervisorJoinJob.run(BSup ervisorJoinJob.java:355)
    at com.tridium.exporttags.BJoinJob.run(BJoinJob.java: 126)
    at javax.baja.util.Worker.process(Worker.java:165)
    at javax.baja.util.Worker$Processor.run(Worker.java:1 38)
    at java.lang.Thread.run(Thread.java:722)
    Message [10:15:31 12-Aug-13] Finished tracking Supervisor-side Join
    Failed [10:15:31 12-Aug-13] Job Failed
    com.tridium.exporttags.util.ExportTagException: Supervisor Join failed
    at com.tridium.exporttags.BSubordinateJoinJob.run(BSu bordinateJoinJob.java)
    at com.tridium.exporttags.BJoinJob.run(BJoinJob.java)
    at javax.baja.util.ThreadPoolWorker$WorkerThread.run( ThreadPoolWorker.java)
    Melbourne
    Quote Originally Posted by refrige-nate View Post
    or any native niagara point with a point tag it fails, Any thoughts? ... $20at$20Exeter
    Just the only thing I can think of is maybe the spaces in the Station name causing issues somewhere. Perhaps a little bit of code in the ASD driver doesnt behave exactly as expected. as in ...
    return SlotPath.escape( SlotPath.unescape( pattern.format( component ) ) );
    ...or something like that
    maybe try taking the spaces out of the Jace name
    1 + 1 = 3 ( *** for very large values of 1)
    Be brave. You cannot get eaten by an imaginary tiger.
    New Hampsha'!!!
    Gave that a shot, still doesnt like it. Definetly must be something in the ASD driver that doesnt like the path
    Mar 2006
    Omaha NE
    have you made sure that the asd.jar file is in the server too? We have had this issues with other things like the spyder tool. Once we loaded all the spyder tool jar files on the server everything started working
    Melbourne
    Quote Originally Posted by controltec View Post
    good point...now that, I reckon is very likely to be the issue!
