Results 1 to 13 of 14
    Jan 2013
    Dyersburg, TN
    Water flow and Delta T
    Had a pump guy in on a job yesterday. He was saying that if you have too much water flow through a chiller you delta T will be closer. Is that true?
    Jan 2011
    If by closer you mean decrease, the answer is yes. There is a very basic principle here that you may want to take the time to learn.
    The tonnage of a chiller can be determined by the following formula: Tons = GPM X DELTA T / 24. For example, if you have a 100 T. chiller that is designed to produce a delta T of 10*F then the flow would have to be 240 GPM. 100 = 240 x 10 / 24. Using the formula, one can see if the GPM is increased then the delta T has to decrease to get the correct answer. The 24 is a constant and the tonnage isn't going to increase if the flow increases.
    Jan 2013
    Dyersburg, TN
    The machine that i have is a 30 ton designed to do 10* t at 100% at 65.3 GPM. I am get a 9.7 delta T at 50 %. So does that mean i am flowing to much water? I have a pressure drop of 14.56 ft head the design is 12.6 ft head
    Quote Originally Posted by jeremyr325 View Post
    at 65.3 gpm and 10F, you have a DESIGN LOAD of 27.21 tons. if you push more evaporator water through the barrel, then your chiller has to work harder to remove the same heat load at the same conditions because the water flows through the barrel faster and has less time to give up its heat. if you are getting a 9.7F drop at 15 tons, then you aren't flowing the same water as designed or something has changed from design. at 14.56 feet of head versus 12.6 feet of head, you are flowing about 8% more water. keep in mind that we are assuming that your design is water and that you have water in it now. other fluids (glycol, etc) change things dramatically.
    "Right" is not the same as "Wise".
    Oct 2010
    Check out bell and gossets system sizer app for smart phones,it can take design chiller barrell drops and calculate flow based on actual readings and also give tonnage
    Apr 2011
    Southern Indiana
    Quote Originally Posted by KnewYork View Post
    Where did you get the 240?
    Dec 2014
    New Mexico
    Quote Originally Posted by SanchezHVAC View Post
    Look at the math that was used. Multiples of 10 were used for the example, so he came up with 240 gpm.
    If you know the gpm then you can figure tonnage. To find the gpm you will need the original spec. for the chiller.
    Sent from my iPad using Tapatalk
    Feb 2016
    Louisburg Kansas
    You can calculate the chiller Cv. That is done by dividing the design GPM by the square root of the design delta p. To obtain flow multiply the Cv times the square root of the measured delta p.
    Another way is to get flow is to multiply the design GPM times the square root of the measured delta p divided by the design
    delta p.
    Thomas Jefferson
    Dec 2014
    New Mexico
    Click image for larger version.
ID:	808214I hope that picture came thru clear.
    Dec 2014
    New Mexico
ID:	808216Dang it fat fingers!
    Dec 2014
    New Mexico
    God lord this is the picture . Ignore the others.Click image for larger version.
    Dec 2014
    New Mexico
    Don’t forget only use one gage to take your readings. That takes gage inaccuracy out so you don’t chase your tail.
    Apr 2011
    Southern Indiana
    Quote Originally Posted by Chev5372 View Post
    Thanks a lot! Especially the pics. How do you upload pics on here?
