The torch model number is WH270FC-V.
I have a small Victor oxy-acetylene set (MC) and I have been told rosebud style tip is the best. can anyone give me a specific model number or opinions on the best tip to use for 3/8-3/4" line sets ? Also suggestions for pressures on both acetylene and oxygen. I have been using around 7.5 PSI for the acetylene and 20 PSI on the oxygen. Seems like a lot though. Thanks for your input.
For 3/8-3/4 a #2 tip is all you need. Rosebud is overkill.
Why is it that those who complain the most contribute the least?
MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
rosebud will eat act. Do to Victor/s website for pressures. Your pressures seem too high.
Doug
I use a #15 rosebud with 5PSI acetylene and 40PSI oxygen. Tanks last long enough, although the company buys the tips and the gas! :P
Thanks for the insight folks ! All input is appreciated.
Geez. I have a little mc tank with #15 rosebud. I crack my valves at torch and set act to 7 and oxy to 11. That is plenty enough. I was brazing 2-1/8 and using 45% on 2-5/8 with no problem.
A #2 tip set at 5/7 should be plenty
I use a #2 tip and about 3-4# of AC and 20# of O2... works fine.
Raise the AC a little if you are doing a lot of 7/8, works a little faster.
GA-HVAC-Tech
GA's basic rules of home heating and AC upgrades:
*Installation is more important than the brand of equipment
*The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
*The value of comfort, over the long term; leave economic choices behind!
Choose your contractor wisely!
Plus 1 for the 15 rosebud. And I really like the small NRP handle with Smith hoses. I do like the Smith handle and their rosebud is nice for smaller pipe.
Cool, I'm gonna lower my oxygen pressure.
You need to do some home work on your pressures. No offence meant here but your oxy pressure is way high for brazing. That is what you set the oxy if you are burning. A rosebud tip is for big pipe and copper to steel brazing. As stated above #1 and #2 tips are plenty. 5 psi acetylene and 5 psi oxy is what I use for 90% of my work. This comes straight out of the Harris book and the instructions that came with my rig. Some guys say 3-5 some even say 7 but the instructions say 5 and 5. Either way the pressures should be the same for brazing and soldering. Now if you are burning then 7 and 40 is the prefered setting. Again right out of the book. Setting your oxy that high makes no sense because you just regulate way down at the handle. Again no offence meant here. I know everybody has different settings they are use to. But if you read the directions that come with your rig or check a welders handbook you will see that your pressures are to high. Keep in mind that manufacturers differ slightly.
I have a #15 and I had to call united refrigeration when I first got mine because it would stop working and be hotter than heck!! I found after they asked for me that my pressures were wrong. I wrote down on my gauges what settings are for #2, #15 and cutting torch incase I forgot again. lol I believe though my rosebud is 10 and 10 for settings.
Yeah, just old habit carried over from the cutting torch. I still like a rosebud on smaller pipe though.
Isn't sanity just a one-trick pony anyway? I mean, all you get is that one trick, rational thinking, but when you're good and crazy, well, the sky's the limit!
I was taught 5/15. No. 2 tip. Seems to work well for residential stuff.
Sent from my HTC One using Tapatalk
GA-HVAC-Tech
https://www.hvac20.com/ High efficiency equipment alone does not provide home comfort and efficiency. HVAC2.0 is a process for finding the real needs of the house and the occupants. Offer the customer a menu of work to address their problems and give them a probability of success.
Find contractors with specialized training in combustion analysis, residential system performance, air flow, and duct optimization https://www.myhomecomfort.org/
