Results 1 to 10 of 10
    Jul 2009
    new york
    What is the code on the max voltage imbalance for running a three phase motor
    I cant find the % anywhere. I was thinking it was 5% but not sure
    Aug 2012
    Gulf Coast
    3% back when I was in school, 00-04, I think 4% max now is standard
    Sent from my SCH-I500 using Tapatalk 2
    Jul 2009
    new york
    Quote Originally Posted by ReferYankee View Post
    How about the starting current drawn by a single phase motor how much can that exceed running current Is it 2 to 3 times or 7 to 9
    Quote Originally Posted by bwd111 View Post
    Not a code but a NEMA standard 2%
    Oct 2012
    Los Angeles, CA, USA
    2% max voltage imbalance and I believe inrush is 5-8 times the normal running amps
    Dec 2012
    columbus, OH
    Here is another good thread on the subject. http://hvac-talk.com/vbb/showthread....amp;p=15366761
    May 2010
    Canada
    They are teaching us 2% voltage and 10% amperage in school as good practice ( not sure about code )
    Dec 2012
    columbus, OH
    Quote Originally Posted by eddiegoodfellar View Post
    You have an NCCER curriculum at your school?
    Jun 2013
    Never really thought about it . You kind of lived with what the power company gave you . Unless it was TOO bad & the power company found something was defective .
    Best I remember , you can get a pretty large imbalance on open delta 3 phase 240 VAC ?
    Do some of the rural power companies still use open delta ?
    I have also seen 240 VAC run 255 VAC . 480 VAC at 500 VAC fairly common .
    God bless
    Wyr
    maple ridge, bc
    In Canada the maximum deviation from averaged voltage in 3 phase circuits is 2%. Not sure what single phase supply % is allowed as there is no deviation phase to phase or phase to ground.
