    Dec 2011
    GE 5KSP39FGW452S Condenser Fan Motor
    Hello.
    My GE 5KSP39FGW452S condenser fan motor has vents on each end, but, is a 230 volts AC, shaded-pole model. Will it be ok if rain blows on it?
    I was wondering since it doesn't appear to have any uninsulated electrical parts which could be damaged by water.
    how is the motor mounted? shaft up? shaft down? shaft horizontal?
    "Right" is not the same as "Wise".
    Southeastern Pa
    Quote Originally Posted by Tetracomm View Post
    Hello.
    If it IS a "condenser fan motor," then it should be RATED for outdoor conditions.
    I suspect you have a BLOWER motor.
    The GE site should have your answer.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
