Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
  1. #27
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by madhat View Post
    Did the Cooler have lights in it before? It just doesn't sound right that the LED's are overheating the cooler, as they run cooler than any other lights.
    I Agree Mad.
    The LEDs that I've worked with run waaaaay Cooler than the Incandescents & Fluorescents.
    I recently installed a low profile Halo "Barn Light" that supplies a Mind Blowing 8000 Lumens, & it has very little heat produced.
    I do know that some of these LEDs are "position sensitive", as in being installed "Right Side Up/Forward", which can cause problems, but overall I'm very pleased with these lights.
    http://www.cooperindustries.com/cont...series-ins.PDF
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
  2. #28
    Have you tried e-conolight on the web? I think they are a Cooper Industry Supplier. All my upgraded exterior lighting is from them, I went from the Hubbell 300 and 500 watt Halogen tubes to them at 76 watts each. They throw out more light than the Hubble 500 watt, and the fixtures are every bit as rugged. Only thing I missed was the Hubbell's had a tether, which made them easier to hang.
    Retired, after 43 Years
  3. #29
    Mar 2015
    Hamersville, Ohio
    No Sir, I haven't tried "e-conolight", but I will see what they have to offer.
    On some of these lights, I've had to improvise with Hangin' wire, or a long tie strap, to hold the device, till I finished the wiring.
  4. #30
    Sep 2006
    Yes had two 16 watt florescent bulbs, the ballast were located outside cooler. The ones installed were LED stick type. Everything was included
    In the stick. Two were installed and they are bright. Thinking about putting dimmer control on them.
  5. #31
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by oldfart View Post
    Can a "Dimmer" be used without causing problems on a LED Old?
  6. #32
    Sep 2006
    I have some 120v LED bulbs under a cabinet, I have one of the old 3 touch settings used in desk lamps, works great. I am also using one of the stick type, with the same touch lamp dimmer, it also works great. Just connect the sense wire to some metal duct tape, stick where you want.
  7. #33
    Mar 2015
    Hamersville, Ohio
    So You've had no Issues with using a "3 touch setting" oldfart?
