Results 14 to 26 of 33
    SC
    LEDs are quickly becoming the way to go as color properties have improved dramatically and cost are rapidly declining. If you are considering installing dimming flourescent I have one recommendation - don't! Over thirty years in the business and flourescent dimming has been and still is a big problem and a headache. LED light sources approved for dimming are the way to go. We are using LED fixtures for interior and exterior lighting applications with much success. Yes, they cost a little more depending on the type and quality but the life is much greater, control is much easier and the energy usage is much, much lower.
    Apr 2018
    Quote Originally Posted by AwareS
    From the monetary perspective, fluorescent tube is cheaper; however, it has some drawbacks such as long activation time and brightness decline within a short period of time. And hence, I replace the fluorescent with LED by having the brief conversion calculation on power.
    I agree with you that LED comes with brighter illumination, but most importantly, it uses lesser power!
  3. Likes DavidDeBord liked this post.
  4. #16
    Mar 2015
    Hamersville, Ohio
    Since my last post, we've begun installing several of these units, with very little problem, at a reasonable cost, & the Customers being very satisfied.
  5. #17
    Jun 2016
    Saavannah GA
    Ive been switching over fixtures to direct wire 4ft T8 bulbs. So far out of the 200 bulbs Ive had one failure. The price on led fixtures is falling so fast its ridiculous. I had planned on replacing bulbs in some recessed cfl fixtures with LED bulbs, but now the price of replacement fixtures has dropped below the cost of the bulbs. The cost of the bulbs was already below the cost of two cfls and a ballast. Plans also include 30 400 watt parking lot lights.
  6. #18
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by billi1905 View Post
    I’ve been switching over fixtures to direct wire 4ft T8 bulbs. So far out of the 200 bulbs I’ve had one failure. The price on led fixtures is falling so fast it’s ridiculous. I had planned on replacing bulbs in some recessed cfl fixtures with LED bulbs, but now the price of replacement fixtures has dropped below the cost of the bulbs. The cost of the bulbs was already below the cost of two cfls and a ballast. Plans also include 30 400 watt parking lot lights.
    I'm wondering what Affect the "Tariffs" will have on Availability & Pricing Billi?
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your Gods law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, I wasnt sent to anyone but the lost sheep of the house of Israel.
  7. Likes billi1905 liked this post.
  8. #19
    We had office workers complaining about the LEDs being too bright. It would have cost a small fortune to put the light switches in with the 0 to 10 dimmer and new wiring in the walls. Electricians put prewired ambient light switches in the ceiling aimed at the windows, and set the light high limit. This saved even more on lighting.
    Retired, after 43 Years
  9. Likes billi1905 liked this post.
  10. #20
    Jun 2012
    Northern NV
    I've installed hundreds of the direct wire 4' T8 LED's and they are quick to install, run very cool, as in reducing building loads, and have gotten several nice rebates from the power company to do so.
    One thing not often mentioned is the power saved by reducing the A/C loads. It is big. Also replacement costs.. Fluorescent bulbs last about a year in 24/7 service. Cuts man hours in maintenance. 5 year warranty too.
  11. Likes billi1905 liked this post.
  12. #21
    Jun 2016
    Saavannah GA
    Anyone have thoughts on recessed LED retrofits. Ive got over 100 tecessed CFL fixtures which are now 15 years old and ballasts are beginning to fail. Ive seen some plug in LEDs ($15 ea x2 per fixture) , (I prefer ballast bypass) and there are several types of Recessed LED fixtures with a very wide range of costs. ($30-$150) Of course its 277 which makes everything harder and more expensive. The one Im looking st right now is a lithonia fixture that just pops in the hole. Its just barely recessed and has a translucent cover unlike the open fixtures we have now. Any thoughts?
  13. #22
    Jun 2012
    Northern NV
    Shallow recessed retrofit LED have a glare issue. Have tried a bunch, but I did find one that is dedicated LED trim for a LED "old work" can that works well for me. Deep recess on lamp. Black ribbed trim. Disappears on a huge ceiling, yet does a better job of illuminating the floor evenly. Something the CFL's do not do well. We are in the process of replacing all of the CFL's with these. Ours are 120VAC, but I believe that they are multi-volt.
  14. Likes billi1905 liked this post.
  15. #23
    Virginia
    Quote Originally Posted by Juan Madera View Post
    Do you bypass the original Ballast , and direct wire them to 120v ?
  16. #24
    Sep 2006
    I installed LED lights in a pastry cooler, they added enough heat to warm the cooler 5-10 degrees. The unit thermostat was in the top as well as the lights, now the cooler will not shut off while lights are on! There is no circulating fan in the unit!
  17. #25
    Did the Cooler have lights in it before? It just doesn't sound right that the LED's are overheating the cooler, as they run cooler than any other lights.
  18. #26
    Atlanta GA area
    Quote Originally Posted by Snapperhead View Post
    We did a couple of those jobs in the winter... dozens of 4 bulb troffers on each job...
    We trashed the ballasts and direct wired... the local supply house had a kit with new 'tombstones' set up for one end power (other end was just to hold the bulb in place). The kit was something in the $5.95 each area if I remember (could have gone up since then).
    Anyhow... get rid of the ballast, direct wire, and use direct wire bulbs... works GREAT!
    And the bulbs we used... are 3500K temperature and have a 50,000 hour warranty.
    Easy $$$...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
