Results 1 to 8 of 8
    Aug 2008
    San Clemente, CA
    How "not" to install a condensate drain line
    No trap clean-out, no vent. This drain deserves an "F". It can "Air Lock" because there is no vent after the trap. With no overflow safety switch, no clean-out and no vent one is just asking for several thousand dollars of damage due to condensate water backing up and overflowing the cooling coil drain pan flooding out this interior furnace closet. I was giving an estimate to replace this system as it was not operating, but had it been operating and this was a service call I would have not left it running in this condition. I would have made corrections unless the customer refused to and signed off on this statement.
    "Install not up to industry or manufacturer standards, not responsible for any water damage due to installation conditions."
    How many years has this been like this? 20 or so and no one sees this? What an industry. I think plumbers know they need to vent drain lines that is like 101 plumbing.
    Water liability now days is such a huge problem with mold and everything else that can happen there is no short cut to how we do it. Per Lennox factory specs I helped to design and illustrate I know how to do it right. Do this and condensate problems will be just about nil as long as you glue up the fittings and properly route the piping. If anyone is questioning the Rubitex insulation around the trap it is because the water in the trap is very cold and the trap would condensate being it is located in unconditioned space. The clean-out tee is one-inch so the Gallo Gun cone fits easily into the tee. See we have thought of everything.
    John
    Jan 2011
    Why does it need a trap at all? We seldom trap a coil drain in a positive pressure instance. Fan coil always gets trapped.
    Mar 2002
    fort walton beach fl.
    Quote Originally Posted by jimmyed View Post
    Same here. On Gas furnaces I normally just have a T for a vent and clean out.
    http://acfwb.com/
    "The best preparation for good work tomorrow is to do good work today"
    Apr 2012
    winnipeg
    I AGREE the local utility makes us do things a normal human would not......what happened to air behind water... worked the last 35 years for me
    Mar 2019
    T vent for A-Coil
    Quote Originally Posted by smurphy View Post
    The t-vent for my A-Coil drain pan is 3/4". I am not sure why it is so big. Is it is a small residental system. The top of the "T" gushes hot air when the furnace is running. I don't want that kind of warm air in my basment. Can I put a cap on the A-coil drain pan condecnsate line?
    thank
    You do realise the first drain looks big time like a home owner speical to me
    Mar 2016
    Pahrump, NV
    Quote Originally Posted by hardtolee View Post
    thank
    hardtolee, it would be best for you to start a new thread in the AOP Section for this question.
    This thread is more than six years old. Not many people will read it.
    It's an upside down world we live in.
    Nov 2008
    DFW,TX
    Quote Originally Posted by JKopp View Post
    John
    this really isnt wall of shame material but we get your point lol we do this more in attics per code because of the temp differentials but closets are rarely much different then home ambient..also a T vent not needed for short runs into a condensate pump or huge line under the return..vents are typically for long runs with a lot of turns etc, helps promote better draining for sure but picking on a 15 yr old install makes me giggle as you are comparing it to brand new one
