+ Reply to Thread
Results 1 to 12 of 12
Thread: BTW-KEY-3 BACTALK FOR WINDOWS
    Phoenix Metro,AZ.
    Does anyone know what if any versions of "Envision" that this key will work on??
    Jim
    Dec 2006
    What? Who? Where?
    USB or serial key?
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Interoperability? You can't handle interoperability!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
    Mar 2009
    VB
    The BTW-KEY-3 BACTALK FOR WINDOWS is probably a serial key and will only work with bactalk for windows. Envision for bactalk or "EBT" uses a usb key so it would say ebt on it.
    If I would of killed my wife when I first met her, I'd be out of jail by now!
    GET SOME!!
    Dec 2006
    What? Who? Where?
    So that would mean it only works with BACTALK below 2.0? That is what I have been told.
    kontrol out
    "Good" - Jocko
    Mar 2009
    VB
    Correct
    GET SOME!!
    Phoenix Metro,AZ.
    Yes, it is a serial key...
    BTW-KEY3 is the label on the key.
    Jim
    Nov 2005
    The new ebt 3.0 is a software key no more usb key that you needed on ebt 2.6 and down.
    Phoenix Metro,AZ.
    So the BTW-Key-3 is not compatible with any version of Envision ??
    Nov 2005
    if it is a serial port key then I would say an early version of envision, I have a usb tech key for envision that I have used on ebt version 2.0-2.6 I now have ebt 3.0 which is the newest version and it is a software key and is locked to the pc I have it on much like your windows lisence.
    Oct 2008
    Midwest
    BTW-Key-3 serial is good up to 1.3. Serial tech keys are good to 2.6. 3.0 is software only. The biggest issue is newer pc's and laptop's no longer have serial ports to service older jobs so converters are in order.
    Jan 2011
    Bartlesville, Ok
    Sorry folks. There was a changeover that went to 3+ key from the key 3. The 3+ will work with EFB 1.3, but the straight key 3 is limited to a much earlier version, Bactalk for Windows as opposed to Envision for Bactalk.
    Apr 2012
    The 3. X version of Niagara is embedded in 3.0, which is actually the authorization of Niagara
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
