Page 27 of 29 FirstFirst ... 1720212223242526272829 LastLast
Results 339 to 351 of 365
  1. #339
    Jul 2010
    US of A
    Quote Originally Posted by jmac00 View Post
    NO THEY WON'T, as more people switch to electric, they will discontinue the gas tax and replace it with a "highway use tax". which will cost the consumer even more money.
    The highway use tax is-will be used to compensate for losses in the gasoline tax as we convert to electric cars.
    You are just stating your opinion here.
    What would be a better way to achieve the status quo?
    Signature removed Violated rule #15
  2. #340
    Rochester, NY, USA
    Quote Originally Posted by pageyjim View Post
    actually, too late, Oregon has implemented a program and Pa is studying it
    https://www.pennlive.com/news/2017/0...ng_tested.html
    http://www.myorego.org/
    PANIC
    Rarely works
  3. #341
    Jul 2010
    US of A
    It is stating pretty much what I said.
    You said consumers would pay more and I asked you what would be a fairer way to transition.
  4. #342
    Atlanta area
    Quote Originally Posted by Missouri Guy View Post
    Aren't you the one that is changing the subject
    Sent from LG Stylo 4 using Tapatalk
    You both changed the subject -- and the topic of this thread.
    Take your schoolroom BS to your own thread.
    Show a little decency, FCOL.
    Vacuum Technology:
    CRUD = Contamination Resulting in Undesirable Deposits.
    CRAPP = Contamination Resulting in Additional Partial Pressure.
    Change your vacuum pump oil now.
    Test. Testing, 1,2,3.
  5. #343
    Apr 2012
    Quote Originally Posted by Space Racer View Post
    I just saw this....sorry about this.... peace
  6. #344
    Southeastern Pa
    The consumer pays for everything...... including every ideologically-driven bad decision that activists can make.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  8. Likes Missouri Guy liked this post
  9. #346
    Jul 2010
    US of A
    I assume this is regarding the VMT.
    What is the problem with a VMT? It used to be all done with the fuel tax. Do you think that electric car drivers should get a free pass and let the gasoline taxes pay for them?
  10. #347
    Apr 2012
    Quote Originally Posted by BBeerme View Post
    How many amps if using 120?
    It's going to be less than 15 for sure..I am going to go with 11 to 13.
    About 25 percent is lost as heat with the smaller charger..so charge rate about a about 1kw an hr give or few percentage points..If I remember right 240v is about 4 to 5 times faster for Tesla which is doable for charging after you get off work and plug in for morning
  11. #348
    Jul 2010
    US of A
    12-16 depending on the outlet and charger being used.
    https://teslatap.com/articles/tesla-...harging-guide/
  12. #349
    Apr 2012
    Thanks according to your source..it is 12 amp on a standard household outlet.
  13. #350
    Jul 2010
    US of A
    Yup it seems you were right on the nose.
  14. Likes Missouri Guy liked this post
  15. #351
    Mar 2010
    Sunny SoCal
    all of this is going to get worse. More and more communities are demanding house holds go "renewable energy" or solar. Engineers are now going to have to figure in the amount of solar necessary to charge a car or truck?? How is that going to work. How much is this going to add to a renewable energy system?
    In new Yorkistan, capt'n Corruption Cuomo is demanding NYS be "completely renewable energy by 2050, but the legislature is trying to "up that to 2030.
    I'm am curious as to what the power companies think of this. This will very well but them out of business
    After enduring the past few California wind driven fire storms (was evacuated @ 01:00 a year ago next week with the Woosely Fire) that overwhelmingly were caused by power companies, the end may be near for business as usual with power companies.
    Something's gotta give.
    Less dependency on these large monopolies would be a good thing.
    Eric
