Page 5 of 6 FirstFirst 123456 LastLast
Results 53 to 65 of 66
  1. #53
    Jul 2018
    Ok thanks for your help. Do your saying I prob need freon
  2. #54
    Jan 2019
    Hi There, I have a 99rmt and we are having an issue where the mix is constantly coming out of the Air Tube and Air Meter. We are using the bag in box system. Do you need to adjust the push pin cylinder so that the flow decreases and will this then decrease the pressure and stop the mix coming out of the air meter??
    If not can you please advise how we can stop the mix coming out of the air meter. We have checked all tubing etc in the MTS system and all ok?
  3. #55
    Jul 2018
    Quebec
    If you have mix comming out of your air metter this means thats you have pressured mix and air coming back from the cylinder. This also means that you probably have bubbles in your bag and the duckface inlet gasket probably comes off in your bag from your mix tube.
    I would check if the rolers on your rmt pump are used or stuck, If your c-clamp under your rollers is not tight enough or dose not pivot on its axis easily , or your rmt hose is very use
  4. #56
    Jan 2019
    Hi Techbob109,
    You were right. the c-clamp was stuck stiff and we removed cleaned and lubricated adn now working a dream .
    Thanks so much for your help
    Regards
    Brian
    Quote Originally Posted by TechBob109 View Post
  5. #57
    Jan 2019
    Hi There,
    I have a query in relation to some of the parts we are using for the MTS with a BIB (Bag in Box System). We have two locations with two 99 RMT's in each location. However the parts that were supplied to each location at the time are slightly different and I am wondering if this might be affecting the overun.
    In the Image for Machine B the Tube-Assy Mix Inlet is the one used when not using BIB system and the Clip Tune Retainer is also use.
    In the image for Machine A we are using the Tune-Assy Pickup (Part no 117022) which is correct for BIB.
    Any advice on whether we need to change the Tube-Assy in Machine B would be much appreciated.
    Brian
    Image B
    Image A
  6. #58
    Jul 2018
    Quebec
    The principal is the same the only thing that can affect your overrun is the air meter. If you have the same mix and the same airmeters the product should be exactly the same
  7. #59
    Jan 2019
    Too much pressure Electrofreeze 99RMT
    Hi There,
    We are having an issue with pressure in our 99RMT. When we are busy the ice cream is spluttering alot when dispensing and even breaking cones. How can I adjust the pressure to reduce this?
    Any help would be very much appreciated?
    Brian
  8. #60
    Oct 2019
    I have a 30RMT that everyday it turns gritty and into like butter. The temperature is reading 19 degree’s. We have taken it apart put new blades, Transfer holes. What could be causing it to become gritty in less than 24 hours?
  9. #61
    Jul 2018
    Quebec
    Is it both side? What size air meter di you have on there and do you put it in night mode everynight?
  10. #62
    Jul 2018
    Quebec
    Brian Mingles: These rmt models are equipped whit a pressur switch that is not ajustable. Does you machine pop those rmt hoses with the red line?
  11. #63
    Oct 2019
    Yes both sides are doing it and i have 19 on my left side and a 17 on my right. We do put it in night mode
  12. #64
    Jul 2018
    Quebec
    Do you hear it working abnormally long when you start her up in day mode? And each time you serve a cone its should run exacly 12 seconde!
    Or maybe check your 5 minutes timer (little black knob on each side of the switches) they are maybe faulty
  13. #65
    Jan 2019
    Water or Air Cooled
    Hi Techbob109. A quick question that you might be able to help me with. I have two units using water cooled machines. We are opening a third unit and our Eelctrofreeze supplier in the UK is recommending air cooled machines. We had previously bought the water cooled through supplier in Holland.
    The unit will be very busy and am concerned about how the air cooled machine will cope with putting out high volumes of mix on a busy day. Ventilation wont be an issue as the unit is an open top kiosk.
    Any advise from your experience would be very much appreciated.
    Brian
