Controller is on a Beverage Air kegerator. Need to lower set temp to 31 degrees which is lower than the factory set low of 35. The manual is complex. Is there an easy way to lower the minimum temperature?
Because your profile states you are a tech, I moved your thread to the “Refrigeration and Ice Making” forum. The AOP-Commercial forum is where equipment owners can ask non technical questions.
Please take note of this new location as the "Moved" icon in the other forum will only last a day.
Me thinks the controller will go 2 degrees below set point before it opens.
35*F set point will be 33*F cutout.
I maybe wrong.
Consult with Beverage Air.
Related Threads
HVAC-Talk: Heating, Air & Refrigeration Discussion
