Sensi-Touch "Slow" cycle rate question.
9K views 3 replies 3 participants last post by  ss120396
#1 ·
The Sensi Touch thermostat has no adjustable swing differential but does have a "Slow" "Medium" and "Fast" cycle rate option. Can anyone who owns or has installed these units give a guesstimate of what the swing differential might equate to for their "Slow" setting? They claim the "Medium" setting is best overall to keep the set temp within 1 degree but I'm after what the "Slow" setting does in relation to swing differential. I'm hoping the "Slow" would act similarly to using a 1.5 or 2 degree swing like other tsats do to give me a longer run cycles when I want them.
(I've emailed Emerson and haven't heard back so I'm throwing this out to you folks)
#3 ·
Experiment? That would involve purchasing it, having it hooked up by a professional and then possibly finding out it's not what i want. I posted this post to avoid just that but thanks for the input. :)
#4 ·
There is no fixed swing differential - that is a common feature of cheap, low quality digital thermostats. Better quality thermostats like the Sensi use a much more advanced, P+I algorithm that continuously recalculates the swing differential to meet the cycle rate setting at your current load.
At a given cycle rate setting, when loads are low or if your system is oversized, and meets the setpoint quickly on each cycle, the swing differential might have to be quite large to keep the equipment cycling too much for the setting you picked. Other the other hand when the equipment is running a larger percentage of the time, it will be able to give tighter temperature control.
Keeping all other circumstances equal, a higher cycle rate setting will give tighter temperature control, at the cost of being harder on the equipment and (potentially, depending on the equipment type) leading to lower efficiency. You want to pick the lowest cycle rate that keeps you comfortable.
