Relocating return air grill
112 views 6 replies 5 participants last post by  pecmsg
#1 ·
Hi all
I want to relocate my return air grill. I boxed out a plenum for it which the HVAC installer told me to do many years ago. The installer is not around anymore. I want to reduce the plenum height by 200mm and put the grill on the underside of the plaster so it faces toward the floor. I can increase the depth of the plenum if needed, but I need to reduce the height
The box out is approx:
660 deep x 1170 wide 650 high (mm)
The actual grill is approx:
490 wide x 1000 wide (mm)
There is a duct that comes from the left into the plenum. The duct is approx 400mm diameter.
Photo of plenum and duct attached.
HVAC is a reverse cycle daikin FDYQN200 ducted 20kw system. Specs are attached.
Am I absolutely mad? Or is this possible without breaking my system :/
#2 ·
Welcome to HVAC-TALK.
I moved your thread to the "AOP Residential HVAC and Refrigeration (Beenthere Zone)" forum as this is the only forum where homeowners can ask non-technical HVAC/Refrigeration questions, and seek advice.
Please take note of this new location.
Save
#5 ·
Sorry I have drawn another photo. I want to move the grill to the underside of the bulkhead (arrow in blue). Then I want to reduce the height of bulkhead by 200mm (arrow in yellow). The bulkhead is the plenum I’m referring to. It’s just a box plastered up. The return air duct is connected to the side of that bulkhead.
I need to make the bulkhead smaller because I need to put a door under it. The door won’t fit at the moment. It’s too tall.
#6 ·
Return air surface is measured in cubic inches. The capacity of the system will give you an idea of how much return surface is needed. Too much surface is not a bad thing, too little is.
Google AI says :
To calculate return air size, determine your system's tonnage, then multiply it by approximately 400 CFM/ton to get the total airflow demand, and finally, use the rule of thumb of 2 CFM per square inch of filter grille area to size your return. Alternatively, use a Duct Sizing Chart or calculator
Save
