5 years ago I purchased a new HVAC system for my house. it came with a 10 year parts and labor warranty.
Recently that company was bought out by another company, but the new company put in writing that they would honor what's remaining on my 10 year part and labor warranty.
The new company sent out a tech to do an AC tuneup prior to the summer, and I have the AC tech on video kicking my unit and damaging it because the tech could not figure out how to remove the panels.
The company did not want to fix the unit so I did a BBB complaint, and they finally agreed to fix the damage.
Just the other day, the company sent a new tech out to replace one panel that had a scratch, after taking the panels off the tech noticed the base of the unit was broke in a couple spots, and almost all the panels were damaged at the bottom where they clip into the base beyond repair.
Now the company has finally said "we will replace the unit with an AC similar to what you have"
I have an American Standard Gold 17 3 ton, model 4A7A7036A1000B. The coil is 4TXCB004DS3HCA.
Again, after talking with the company, they said they are going to replace my AC with a unit similar to what I have. That's all they keep saying.
I emailed the company again and told them that since my current unit is discontinued, they should replace with the unit that replaced my discontinued one
That would be model 5A7A7036A1000A.
If they agreed to replace it with that model, shouldn’t that HVAC company also replace the coil inside the furnace, and also put new lines in because it’s a new type of refrigerant?
Thanks!
Thanks!
