Good day and thank you for the forum,
A year ago, we installed a 14 kW photovoltaic system to generate net-metered solar power. After one year, it is safe to conclude that I have excess solar generation (~ 4k kWh) and I am looking for the most financially attractive options for utilizing the excess. I am not sold on EVs for rural America but have thought of another option and would appreciate any and all opinions.
I have (2) 20 year-old 75-gallon LP fired water heaters...one is used for heating water for everyday use (showers, dishwasher, etc.) and the 2nd is a hydronic auxiliary heat backup when temperatures drop below the lower limit of my heat pump capabilities (<30Ëš). The hydronic unit also provides heated floors on request. We do not fire up the hydronic water heater until temperatures are forecasted to drop below that 30Ëš threshold. The "traditional" water heater consumes about $1,000/yr of LP (@ $3.00/g) while the hydronic unit (as it is only used seasonally) uses around $400/yr of LP.
We are also rural and lose our power on occasion...it is not unusual to be out for a few days. The exhaust fans on both water heaters are connected to our 12k watt Generac standby generator as is our well pump. So we currently have hot water (and heat) during prolonged power outages. The generator was sized for the current arrangement and has no room for expansion.
My thought is to replace the "traditional" water heater with a 75-gallon heat pump electric water heater (HPWH). The HPWH (with installation) will likely run $3k but save me the $1k of LP annually - 3 year payback if one assumes that my marginal electricity cost is $0. This type of unit would consume 1k kWh annually so I have plenty of solar capacity.
The draw for a HPWR is too much for my generator so we would be at risk for hot water in the event of a prolonged power outage. One possible work around involves tapping into the hydronic water heater.
Suppose that I was to connect a pipe between the hydronic water heater and the new HPWH. In the event of a power outage I would fire up the hydronic water heater (if not already on) and turn a valve which would (1) shut off the cold water supply to the HPWH from the well and (2) allow the LP hydronic water heater (which is on the Generac) to supply the HPWH with hot water.
Is there anything that I am not taking into consideration with this concept?
John
John
