Heres my story.
For the past 2 + years we had a dryer that never actually worked correctly drying clothes. It always took a little over 1 1/2 cycles to dry. now the dryer is probably 7-9 years old, so I always chalked it up to being on the older side.
Anyways recently while working outside in cooler weather and the dryer runnign inside, I noticed that no steam or exhaust was coming out of the roof vent. I popped open my attic hatch and took a gander, only to find that the dryer vent was just coiled up inside the attic area, not venting outside. On top of that the flexible vent had a section that was crushed pretty good. Every home owner knows that the dryer vents outside for a reason, so off I went to my local store to pick up a new replacement vent tube.
I hooked the new tube up to the roof vent, which by the way is a 4 inch roof vent with a damper flap and is brand new no clogs in the roof vent, ran the new tube down to the dryer, cut off all unnecessary excess and hooked it up. I also made note to keep the number of bends in the tube vent to a minimum.
To my surpise our dryer is now working worst than before, we've ran probably 5-6 loads through and its taking longer than it did before to complete drying.
My parents have a dryer they just replaced (with a stackable set), that is only 2 years old, I was going to get their old dryer from them but wanted to make sure that everything else in my setup is ok before going through that trouble of moving the dryer in.
I've attached some pictures of my new venting just for your opinions. I know that the flex tubing is not ideal, I know. But I had to use it due to the space requirements in which I am working with.
I know the rules on this forum, I do. So if you guys find this question illegal, ok fine, delete it. But quite honestly, I'd be in more danger if I had not started to work on this than I am now. All I simply am really asking is is there enough believe in your opinion that the problem is within my venting still or that I may have better luck with a different dryer.
Other tidbits of info.
I have just 8 foot ceilings, so the length of the tube from the dryer up to the ceiling is about 9 feet.
In the attic space, under the insulation there is a elongated 45 degree bend, from where the tube enters from the living space, to where it becomes visible in the picture.
The length of tube in the attic space at about 5 feet.
Although the pictures may make it appear, the dryer vent is not crimped or crunched in any manner.
Is my venting the issue or is it possibly just my dryer crapping out? I can't see a dryer running worse than it was before, because the venting before was just BAD. If the venting is likely the major issue still then I'll give my hvac guy a ring and have him come install a new shorter vent, or install some rigided vent. I did not do that before because we have our house up for sale, and I've already bled out way to much money on it.
http://i233.photobucket.com/albums/ee40/rvegab00/DSCF1230.jpg
http://i233.photobucket.com/albums/ee40/rvegab00/DSCF1232.jpg
http://i233.photobucket.com/albums/ee40/rvegab00/DSCF1233.jpg
http://i233.photobucket.com/albums/ee40/rvegab00/DSCF1234.jpg
http://i233.photobucket.com/albums/ee40/rvegab00/DSCF1235.jpg
Thanks!
Thanks!
