Hi to all,
I installed a Carrier system with condenser and FV4 air handler with a hot water coil on top (hydro air set up)
The air handler has a Dh and R circuit for dehumidification, but only in the coil mode (according to the instructions)
It ramps down the blower motor to 80% of normal coil speed.
The customer believes that a HVAC system should also dehumidify in heat mode especially
when it's rainy and cold outside and the relative humidity is high.
What's your opinion? Is their a control out there that can run the condenser and heat mode at the same time
to dehumidify?
to dehumidify?
