Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Residential HVAC
Residential HVAC Questions and discussions pertaining to HVAC for the home. No pricing, no DIY, please read Site Rules Register
Reply
Thread Tools Display Modes
  #1
Old 10-01-2005, 07:29 PM
deleblanc deleblanc is offline
New Member
How do you rate Coleman air-to-air heat pumps? How do they compare to Tempstar? Pros and cons? Bad experiences?
  #2
Old 10-01-2005, 08:13 PM
airworx airworx is offline
just buy carriers performance ht.pump or trane and forget about all the others. theres only a slight differance in the price of a good system and the rest. the real differance in prices is what the contractor sells his equipment for. and the better contractors will sell the better brands.
  #3
Old 10-01-2005, 08:18 PM
a\c don's Avatar
a\c don a\c don is offline
Coleman is basically low end York.
TempStar is ICP with a different badge as is Heil.
I may be wrong but I think both use Bristol compressors, TempStar coils are made in Mexico and are notorious for freon leaks.
I'll probably catch some flak for this, but for around the same cost check out Goodman.
Copeland compressors, better warranty, coils made in the USA.
__________________
We've been doing so much,for so long,with so little, that now we can do almost anything, with nothing at all.
  #4
Old 10-01-2005, 08:32 PM
beenthere beenthere is offline
Moderator
Owned by carrier, which is owned by UTC.
I'd pick the tempstar over the coleman.
__________________
The toes you step on today, may be attached to the butt you kiss tomorrow.
  #5
Old 10-01-2005, 09:01 PM
appltech1's Avatar
appltech1 appltech1 is offline
Me too key-mo-sobbee.
  #6
Old 10-02-2005, 01:10 AM
andserco's Avatar
andserco andserco is offline
ICP (Tempstar) have Copeland scrolls in them...and the premium line of ICP has better warranties than all the above...within a matched system it has a 10/5 warranty and a 5 year replacement warranty ( if the compressor fails in 5 years, you recieve a new unit not counting labor).. The evaporaters are made in Mexico and the indoor coils are actually "Carrier" look real close the ICP indoor air handlers have Carrier stickers on the blower section........
[Edited by andserco on 10-02-2005 at 01:17 AM]
  #7
Old 10-02-2005, 03:36 AM
Jultzya Jultzya is offline
Grumpy Old Man
Yes, you are wrong.
Premium models have Copeland scrolls.
Yes, they are madel in Mexico (like so much other **** ), but I have data that will prove you claim of "notorious" to be incorrect.
To the OP, go with the Tempstar Premium line with the scroll, and if you want a better warranty... look here. Tempstar's cooling products are here.
  #8
Old 10-02-2005, 03:41 AM
Grumpy Old Man
Close....
UTC owns Carrier and ICP
Carrier markets Carrier, Bryant & Payne
ICP markets AirQuest, Arcoaire, Comfortmaker, Heil, KeepRite, Tempstar, etc...
  #9
Old 10-02-2005, 07:10 AM
New Member
In what sense is the Coleman a "low-end York"? Is it notorious for breakdowns? Poor warranty? Inefficient?
  #10
Old 10-02-2005, 07:21 AM
Moderator
Its basically builders grade.
Its the third name in the UPG line up.
York,Luxaire,Coleman,Evcon,Red T,Winchester
__________________
  #11
Old 10-02-2005, 10:25 AM
bornriding's Avatar
bornriding bornriding is offline
deleblanc
Definietly 'Tempstar' over coleman ( who mainly produced mobile home unit before reaching into the res. market)
I have been putting in 'tempstars' for 15 years - never have I had a problem with leaking indoor coils - have only changed out maybe two indoor coils that we installed in those years. Have replaced many more Rheen/Rhuud and 'goodman' coils less than ten years old, than 'tempstar'.
In this case, this is more than MHO, it is fact!!
Also ,before you decide, check the BTU rating of the compressor in the Coleman vs the Tempstar.
Hope this helps,
Richard
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
