Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > Training Forums > Tips 'n Tricks of the Trade
Tips 'n Tricks of the Trade Those special ways of making our job easier and better.
Reply
Thread Tools Display Modes
  #1
Old 09-21-2005, 06:38 AM
billy4662000 billy4662000 is offline
New Member
I justhad a 14 seer American standard unit installed. It is evidently a great peace of equipment but it loses four or five degrees on 95 to 100 degree days. I was told that if I sit the unit on 72 it would hold that all day. This unit has a expansion valve and the subheat is preset. So I understand you are to use the subcooling method to obtain the proper charge. Anhyone know a simple way to find the amount of subcool right befoe the liquid enters the expansion valve. My unit is in the attic and i cannot crawl up there. I just want to check the charge for myself and be sure that it is right.
__________________
Bill
  #2
Old 09-21-2005, 06:43 AM
New Member
the word subheat should be superheat
__________________
Bill
  #3
Old 09-21-2005, 12:26 PM
mark_aanr mark_aanr is offline
Member
billy,
The correct subcooling for a TXV system should be on the plate on your condensor unit.
However you'll need some tools you probably do not have to properly check the subcooling.
But, for a crude check: Put your ear right on the liquid line (small tube)(perferably right before the TXV). If you hear a gurgling sound, then I would call someone to check the unit. If you hear what sound like a steady stream of flow, then I'd be less inclined to think you have a low refrigerant level problem.
Mark
__________________
Mark
  #4
Old 09-21-2005, 03:59 PM
New Member
Thanks Mark. I appreciate your reply. I will do as you suggest.
__________________
Bill
  #5
Old 09-21-2005, 10:16 PM
2hot2coolme's Avatar
2hot2coolme 2hot2coolme is offline
Gaud!!
  #6
Old 09-21-2005, 10:31 PM
derrick1623 derrick1623 is offline
hope he don't burn his ear on that thar copper tubin'...surely he'll sue ya. j/k
  #7
Old 09-22-2005, 12:56 PM
Member
2hot2coolme,
Re: Gaud!!
What? It actually is a fair, quick test that a homeowner can do. I do it everytime I'm up in MY attic and my unit is running. Why make things complicated?
I'm not suggesting he set his subcooling by it; that would be impossible. But it's an easy way for a homeowner to see if they have gas in their liquid line. IF you hear gurgling, then you most definetly do not have a full liquid line. Then he can call someone to service the unit and figure out root cause. No different than if he saw frost on his suction line and called someone to figure out root cause.
Digress...
Back before I was in the business, I had an upstairs unit that was not cooling real well. Only had 8 deg temp drop at the supply. I called someone and told them I was probably low on refrigerant. They came out and said (or told wife) everything is fine. I called them back and got the owner out with the tech. I took them up in the attic and said "now put your ear on that 'thar liquid line. Here that 'thar gurggling? My evaporator is being starved man!"
He said, "Oh, you got one of those TXV thingys". Maybe YOU ARE low on refrigerant. He then proceded to dump gas in the system up the the high side was "a lot higher". No thermometer on the liquid line, no subcooling calulation, no leak detection..."
Mark
__________________
Mark
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
