Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Controls
Controls Discussions about HVAC controls in general including automation, DDC and pneumatics.
Reply
Thread Tools Display Modes
  #1
Old 07-30-2010, 05:09 AM
Napha Napha is offline
Regular Member
AEM 2100 sofware configure
Dear all,
I just bought apogee ethernet microsever (AEM 2100). But I don't have sofware to configure IP and RS232 speed.
May I get it, if any one have it?
Thank
  #2
Old 07-30-2010, 08:10 AM
ntech64 ntech64 is offline
AEMs are just configured with a 9 pin to 9 pin null modem cable and Hyperterminal.
Follow the Getting Started for "Setting Up APOGEE Ethernet Microserver". It should be darn close to seting up the AEM 200.
  #3
Old 08-01-2010, 11:27 PM
Regular Member
I had try with option of EAM200. when I download, at the IP & subnet mask configuration is ok. there are about 20 errors at configuration of channel 1 and channel 2.
What wrong with this error? How can I correct this error?
Thank you
  #4
Old 08-02-2010, 08:36 AM
What are the errors? What are you using to "download" to the AEM?
  #5
Old 08-03-2010, 01:25 AM
Regular Member
I used AEM Configuration Tool 2.6. It doesn't show what is the error. It just count the error when it configure channel 1 & channel 2. Totally there are about 20 errors.
And I use COM(Female) to Parallel(Male) and Parallel(Female) to COM(female) to connect from my laptop to AEM. This converter I bough from Siemens.
Thank
  #6
Old 08-03-2010, 10:37 AM
randy2331 randy2331 is offline
New Member
You have the proper cabling or you wouldn't be able to communicate and set IP address. The cable Siemens uses is a red 9 pin female to 25 pin male and then a null modem that is a 25 pin female to 9 pin female. The configuration tool should be all you need. If there are errors, try resetting the AEM and trying again. If this doesn't work, there is a procedure in your Getting Started manual that takes you through the steps of manually setting up an AEM with Hyperterminal (standard with all Windows OS). If you still have issues, contact your Siemens service rep. If he has a problem with helping you, complain to the service manager. They should have no issues with giving you tech assistance on such a simple procedure.
  #7
Old 08-04-2010, 09:08 AM
Thank
That version of the AEM Configuration Tool does not support the new AEM 2100. Manually configure the AEM using HyperTerminal.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
