Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Commercial HVAC
Commercial HVAC Questions and discussions regarding HVAC for commercial buildings
Reply
Thread Tools Display Modes
  #1
Old 07-30-2010, 12:14 AM
Air flow man Air flow man is offline
Regular Member
Circuit setters for wshp
Question. Circuit setters on wshp are for (gpm) is their only pupose for economy. I realize maintaining flow rates are critical, and minium but proper rates are needed. This saves $ on the pump side of the system,but would max pipe flow effect pressures on the system.,adversally effect heat transfer with to much flow?? Thanks in advance for your in put.
  #2
Old 07-30-2010, 12:45 AM
GT Jets's Avatar
GT Jets GT Jets is offline
Quote:
Air flow man, this question is very loaded, but I am going to take a crack at it.
The circuit setters are there to obtain proper flows on a given system and give some adjust ability to obtain the design specs yes, but it goes further than that.
They allow the system to be "balanced", lets say there are 20 WSHP's and only one pump, if all 20 C.S's were at 100%, you would not have the proper pressure differential on any of the WSHP's and have a real mess on your hands..
Now that being said, if there is only one WSHP, then your pump would have to sized for the gnat's ass and you would have no adjust ability...
As far as problems running wit too much water flow, yes, many many problems. Low head pressure and potential ice ups in cooling and low heating performance in heating....(Heating would be effected less than cooling)...
GT Jets
__________________
If a day goes by and you have learned nothing, I hope you got a lot of sleep.
  #3
Old 07-30-2010, 06:00 AM
atmosphere atmosphere is offline
The circuit setter works as a type of "hold back " device.
They make sure the fluid stays in the vessel upstream long enough to allow the designed amount of heat transfer to occur.
__________________
"Iron sharpeneth iron..."
  #4
Old 07-30-2010, 08:08 AM
flange flange is offline
very high flow through a copper coil can also cause erosion, leading to failure of the heat exchanger, compressor, and unit. too many shortcuts these days causes customers to view us as hacks. say no to hacking.
  #5
Old 07-31-2010, 01:46 AM
PortaChill PortaChill is offline
Regular Member
The purpose of the circuit setters on your wshp set up would be to regulate condenser water flow thru each unit to ensure proper heat transfer. Most setters are adjustable but I had a few Blds. in the past that had fixed orfice type which had become sediment traps(Tower and pumps were high point) on bottom floors of bld.
  #6
Old 07-31-2010, 08:35 PM
Randy S.'s Avatar
Randy S. Randy S. is offline
What Flange said. Double.
__________________
God Bless the USA
  #7
Old 08-06-2010, 12:27 AM
Regular Member
Ok guy's thanks alot. I was trying to ask a question with out being to leading. I'm sorry i didn't do a very good job of it. So here goes, GTJets stated that too much flow would cause low head presures and possible icing of evap coils. (Sounds logical sounds right). I was just wandering(incorrectly) if too much flow could raise head pressures by not enough contact time, i'm assuming volume makes up for it. I was just comparing it to when your blower speed is to high and you have poor dehumidifacation because of contact time with coil being poor. Could i be on to something or am i just way off base.
  #8
Old 08-06-2010, 01:31 AM
Paul Bee Paul Bee is offline
Too much water flow will give you low head pressure along with low suction pressure/iced up evaporator. Imagine putting a higher horsepower condenser fan motor on an air cooled unit, what is gonna happen to the head pressure? And doing it right is critical, a lot of contractors will call in a TAB company to make sure it is done right. The other aspect is efficiency, a unit with not enough head pressure is not very efficient, low head pressures will reduce flow through metering devices, which have capacity ratings dependent on the pressure differences across them. This reduced flow causes a starved evaporator which will cause low suction pressures and high superheats. Water exchanges heat a lot faster than air. Contact time is not an issue. Take your hot bowl of oatmeal and try cooling it off by blowing on it, now set it in a sink of cool water, which works better? Correct temp split on a water source heat pump is around 10 degrees.
__________________
Do the right thing.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
